May 19, 2019, 09:05:12 AM
Author Topic: Camber/Caster Plate (welding required)  (Read 23948 times)
Offline justinsamberg
  • Moderator
« on: July 30, 2010, 06:47:38 PM »
Welding on the four camber plates is simple. Line the notch up with the center line mark on your stock plate. Then put 3 small welds or tacks like what you see in the picture. Using a mig welder will also work fine for this too.
We can provide the welding for you for a small fee, as long as you supply the bolts.
« Last Edit: August 13, 2010, 12:47:44 AM by justinsamberg »
http://www.rx7v8.com/
Pleasant Hill, CA
justinsamberg@gmail.com
925-484-5800
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
Re: Camber/Caster Plate (welding required)
« Reply #1 on: July 30, 2010, 06:54:54 PM »
did ya find out that it just will not work with the single plate?
Josh
Stig's sunglass wearing American cousin
74 MGB GT V8 12.83 (75 shot)
93 402 LS2/T56 Rule 3 No V8 RX7's
  • Moderator
« Reply #2 on: July 30, 2010, 07:38:28 PM »
It will work with the single plate. Did I send you a set of the 4130 steel plates? As long as you have those you should be fine.
Pleasant Hill, CA
925-484-5800
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #3 on: July 30, 2010, 07:50:57 PM »
Ya man I got a 2nd set from ya they are still in the bag.  I have not even put my car back together sense I got tall the parts from you.
Sorry about the random phone call that other weekend from me lol.
Josh
Offline DRTHVDR
  • Come to the Darkside. We have Cookies.
« Reply #4 on: August 04, 2010, 09:32:30 AM »
Would I run in to any trouble if I didn't weld them together?  Will the alignment shop read me the riot act if I don't?
You don't need a better ride, your ride needs a better driver.
93 RX-7 R1 CYM: Bastard
Other: 06 330ci ZHP, 11 Odyssey
Offline crizby
« Reply #5 on: August 13, 2010, 12:30:24 AM »
has anyone found that the bolts are a little bit short on the front mount once the extra plate is welded in?
  • Moderator
« Reply #6 on: August 13, 2010, 01:13:18 AM »
DRTHVDR, you do need to weld the plates on. It can be done with them on the car as long as you have an air gun Handy to cool them off the instant your done welding.
crizby, you're probably noticed that the end of the bolt doesn't make it to the end of the sinch nut. If your worried about it just ad some lock tight, but I really don't think you need to.
« Last Edit: August 13, 2010, 01:14:57 AM by justinsamberg »
Pleasant Hill, CA
925-484-5800
Offline tai-lun
« Reply #7 on: August 31, 2010, 03:08:53 AM »
I actually ran into this and I don't know if the previous owner just screwed too much with the nut or the cars age, but mine is toast. I ordered new ones from Mazda, Justin would I be able to just order 4 camber plates?
The non welded ends on mine were also a bit too tight, we had to drill them out a bit. I'm not sure if anyone else has run into this?
Tai - 93 LS2 Ronin Widebody FD - rebuild time with ITB's soon... :banghead:
Build Thread: http://www.norotors.com/index.php?topic=9172.0
Offline ProjectD
« Reply #8 on: August 31, 2010, 09:40:22 PM »
http://www.norotors.com/index.php?topic=1811.0.html
Offline mdpalmer
« Reply #9 on: December 07, 2010, 01:58:29 AM »
Did you get your new cam bolts from Mazda? I ordered one over a year ago, and the design is different... it's not like a "D", it has a totally different pattern and the corresponding cam plate has the same pattern. I guess I'm going to have to get the old style bolt or have the D shaped hole machined to fit the new bolt. I'll post a pic this week of the new design bolt, in case no one else has seen it.
Mike
My Build Thread
YouTube Vids
Offline tai-lun
« Reply #10 on: December 07, 2010, 10:15:27 PM »
When mine sheared off it was the D shape, I ordered new ones from Mazda and now have the same ones you do which have long cut-lines along opposite ends of the bolt. I am planning to have a machine shop just duplicate the disc if the bolt cant be made to work the same as the D shape ones. I will try to get some pics up as well.
  • Moderator
« Reply #11 on: December 11, 2010, 04:18:33 AM »
If some one can send me a sample washer. I would be more than happy to make some extra sets of these washers to keep in stock for the people that have purchased these later style cam washers.
Pleasant Hill, CA
925-484-5800
Offline tai-lun
« Reply #12 on: December 11, 2010, 10:41:31 PM »
I may have a solution for anyone with later washers and bolts Justin, I just need to find some time to get to the machine shop for a solid day or so but work this month may mean I wont get to it till the new year. I will post progress when I go, we should be able to make things work with no modification to the washers you supply and maybe get around the running out of thread issue that some guys are having.
Offline RX7what
« Reply #13 on: December 11, 2010, 10:55:52 PM »
Justin I think I need a set of tue chrome molly washers. My subframe is from way back in the begining.
PER AUDACIA AD ASTRA
Offline bimbleuk
« Reply #14 on: December 12, 2010, 12:43:08 AM »
Yes mine were so I just used longer bolts and machined a flat on the bolt to suit.
