August 19, 2019, 06:40:30 PM
Author Topic: Transmission mount Installation  (Read 12460 times)
Offline Gunnytron
Re: Transmission mount Installation
« Reply #15 on: November 03, 2012, 07:44:10 PM »
What sort of clearance are people getting between the box and the old mount in the tunnel. I have about 5mm probably.
Offline bimbleuk
« Reply #16 on: November 04, 2012, 01:07:32 AM »
That tunnel brace bracket usually gets removed.
Offline Gunnytron
« Reply #17 on: November 04, 2012, 04:38:27 AM »
Bugger. I was hoping I could avoid that. Ta.
Offline RX7Driver4Life
« Reply #18 on: June 03, 2013, 08:30:25 AM »
Im going to take this on today wish me luck.
I will take plenty of pics.
93 LS1/T56 FD RX-7
« Reply #19 on: June 04, 2013, 10:06:27 AM »
I fucked up i installed the plates upside down. The small bolt is on the top of the trans mount.... No wonder i was havin such a hard time.... Im an idiot. I used the mount to measure the holes but wheni p put the plates i put them upside down. Ughhh thats what i get for doing things in a rush under the rain.
Besides that the trans mount wont clear early hinson tq arm mount on the trans. grinding of the metal plate is required otherwise its straight forward.
93 LS1/T56 FD RX-7
Offline RAPID
« Reply #20 on: June 05, 2014, 06:56:30 PM »
Which aftermarket polyurethane mount is recommended to achieve the 5.50" output shaft to top of tunnel measurement ? Are transmission mounts sold separately ?
My poly mount center bolt stripped out and I'm tired of this heavy granny's mount, I want room for exhaust.
Joe
