January 17, 2019, 10:02:46 PM
Author Topic: LT1 in an 85 GSL  (Read 21022 times)
Re: LT1 in an 85 GSL
« Reply #30 on: January 26, 2017, 03:07:34 PM »
That won't work... didn't think about the steering box.
The drivers side outlet is right where the box is  :(
Unfortunately, I am planning on getting either block huggers or long tubes meant for a Nova
Offline txgs
« Reply #31 on: January 26, 2017, 09:51:44 PM »
Quote
No problem, the radiator mount itself is a granny's piece but I am sure you could fab something similar.  I want to say that is 1" or 1.25" tubing, .065" wall I think with 1/8" steel plates on the ends.  I can try and dig up the template for the end plates but I am not sure if I have it or not
No worries. The specs on the tubing helps and plate size also. As for the template I will mock something up. Thanks Again!
« Reply #32 on: January 27, 2017, 09:11:45 AM »
Quote
No problem, also make sure that it is a super tight fit.  I know I measured the width before I cut the original bar out, and I had to use a large mallet to install it after I cut the bar out.
Offline txgs
« Reply #33 on: January 27, 2017, 08:32:41 PM »
I agree, I will definitely will make it tight before I cut out the factory brace.
« Reply #34 on: January 29, 2017, 03:33:52 PM »
Well things are not going well, looks like engine is seized, maybe I spun a bearing, lots of metal in the valley.  Also cylinder 6 had som water and rust in it, Im thinking this was my headgasket issue
Any advice? Should I do new rings and get a hone, do you think the crank is ok?
Offline gadzooks
  • Got Torque?
« Reply #35 on: January 29, 2017, 07:43:53 PM »
There's no telling until you pull the pan, but if the crank isn't too bad you can get a shop to turn it down by about .010" and run undersized bearings. I would send everything in for a rebuild seeing how the heads will probably need to be milled to remove any warpage
1987 Base/Light Weight with '95 Firebird LT1/T5
« Reply #36 on: January 30, 2017, 08:05:46 AM »
Thanks for the advice, I wouldn't have to touch the pistons or rods right?  All the other cylinders look great and still have crosshatching except for#6 which is a shame.  I was already planning on sending the heads in for a valve job and to get 0.005" taken off as well.  I will take some pictures when I pull the pan and see how bad the bottom end is.
« Reply #37 on: January 30, 2017, 06:44:00 PM »
Not good! Crank and caps have large gouges and the pan was full of metal!
« Reply #38 on: January 30, 2017, 10:17:44 PM »
Sorry to see that.  :'(
To be positive, it looks like it's getting closer to time for an LS swap.
« Reply #39 on: January 31, 2017, 08:15:21 AM »
Lol it is, calling a local place that is advertising 5.3s for 600 bucks, may be cheaper to buy that and add a cam and go from there
Offline txgs
« Reply #40 on: January 31, 2017, 07:54:31 PM »
Would love to see another LS powered FB
« Reply #41 on: February 04, 2017, 11:54:41 AM »
Finished stripping the block last night and was surprised to see such minimal damage to the mains!  I think a line hone will clean everything up nicely.
« Reply #42 on: February 07, 2017, 09:02:35 PM »
Block and rods at the machine shop.  Working on getting some aluminum heads.  Thinking of getting ARP main bolts and rod studs for high rpm security.
Offline gadzooks
  • Got Torque?
« Reply #43 on: February 07, 2017, 10:33:06 PM »
good time for a nice cam and some 30# injectors(my 355 LT1 with  LT4 Hot Cam and 1.6 roller rockers hits 90% duty cycle on stock injectors above 6000 RPM)
« Reply #44 on: February 08, 2017, 10:40:03 PM »
Ordered a Comp 503 cam today!  Will need to look at injectors
