January 17, 2019, 11:07:05 PM
Author Topic: LT1 in an 85 GSL  (Read 21025 times)
Re: LT1 in an 85 GSL
« Reply #15 on: February 10, 2016, 11:20:48 AM »
Here's what a forged LT1 383 with LT4 heads/intake can do.... for some inspiration!
« Reply #16 on: February 11, 2016, 08:39:07 AM »
Thanks, that thing is ridiculous, I think I will need a Ford 8.8 and T56.... :D
« Reply #17 on: July 21, 2016, 09:49:54 AM »
 :wave:
Car has been running good, I had some spark plug wire routing issues in the beginning, but those are fixed now.  My cheap MAF from rockauto stopped working so I am running in speed density right now, definitely a little rich.  Hopefully in the coming months I can purchase the stuff to do my own tuning.  Still needs some small things, and once I start doing some drifting events I will dig more into suspension set up.
Offline gadzooks
  • Got Torque?
« Reply #18 on: August 31, 2016, 10:48:38 PM »
1987 Base/Light Weight with '95 Firebird LT1/T5
« Reply #19 on: September 01, 2016, 09:07:27 AM »
http://www.tunercat.com/
Thanks for the link, I need to get my connector and cable set up.
« Reply #20 on: January 22, 2017, 09:01:50 PM »
Starting teardown, gonna take my time and make the motor look nice
Offline txgs
« Reply #21 on: January 22, 2017, 09:25:35 PM »
Thanks for bringing this up. Although I am installing a 5.3 L33 some of the pictures help out a lot.
« Reply #22 on: January 23, 2017, 08:30:26 AM »
No problem, if you need any pictures let me know, the engine will be out of the car for a while.
Offline txgs
« Reply #23 on: January 23, 2017, 07:42:48 PM »
Can you take a few pictures of the brace that you moved forward for radiator clearance. Thanks!
« Reply #24 on: January 25, 2017, 07:58:21 AM »
Heres some pics, I hope it helps
Offline txgs
« Reply #25 on: January 25, 2017, 09:24:15 PM »
Thanks for the detailed pictures they will definitely provide the needed information I was looking for.
« Reply #26 on: January 26, 2017, 08:58:11 AM »
No problem, the radiator mount itself is a granny's piece but I am sure you could fab something similar.  I want to say that is 1" or 1.25" tubing, .065" wall I think with 1/8" steel plates on the ends.  I can try and dig up the template for the end plates but I am not sure if I have it or not
Offline GuillaumeC
« Reply #27 on: January 26, 2017, 01:03:27 PM »
I have a nice set of header for you, they were used in my FC but they'll probably fit your FB?
They're Headman shorties that had the flanges replaced by 1/2 think LT1 D-port pieces and ceramic coated.
1989 Mazda RX7 Turbo II, 357ci LT1, AI TFS CNC heads, Garrett GTX4708R, Ford 8.8" SAS, TH400. (Current project)
1995 Chevy Caprice, Twin turbo 357ci LT1, 9.96 @ 141.2 mph (sold)
« Reply #28 on: January 26, 2017, 02:59:42 PM »
Im not sure if they will, my rams horns were hitting the steering box bad
Offline GuillaumeC
« Reply #29 on: January 26, 2017, 03:04:02 PM »
That won't work... didn't think about the steering box.
The drivers side outlet is right where the box is  :(
