October 13, 2019, 05:14:45 PM
Author Topic: RX7 GM E-Rod LS3  (Read 1360 times)
Offline goracer
RX7 GM E-Rod LS3
« on: November 21, 2013, 11:12:00 AM »
Is it possible to go over this build in detail? How long did it take? Was any of the GM wiring mated with the Mazda wiring? What engine cradle and mount kit was used? Any fabrication and/or modification (like tunnel being cut for the shift lever)? What was the dyno results? Did the owner get referee CARB approval? Install cost? Is there A/C?
Offline Negrok20r
  • Pre-Staging
dc2 k20 turbo
93 FD under construction
