January 20, 2021, 07:14:03 AM
Author Topic: FC wiper switch relay replacement  (Read 1561 times)
« on: September 20, 2013, 10:36:10 AM »
Do your wipers work at the low/intermittent speeds?   Do they self-park when you shut them off?
If the answer to those questions is no, you likely have one or more failed relays in the switch.   This is a common failure point on these and is repairable with some circuit board work.
I can disassemble your switch, replace the relays, test and reassemble and ship it back to you, good as new (well, better, the relays Mazda used suck).
Cost:  $75.00 + S&H
