June 12, 2021, 10:09:31 AM
Author Topic: Ls3 Small Bore Heads for Ls1 Engines  (Read 16122 times)
Offline Ryan@BallisticSpeedParts
  • Moderator
    • Ballistic Speed Parts
« on: March 05, 2013, 07:44:31 PM »
We are proud to introduce our BSP Small Bore LS3 cylinder heads for LS1/LS6/LS2 engines!
Ballistic Speed Parts LS3 Small Bore cylinder heads are a direct fit to your stock bore LS1 or LS6 engine.  We’ve spent over 2 years developing the ultimate cylinder heads for LS1/LS6/LS2 Engines using GM’s outstanding LS3 cylinder head as our platform. We are proud to offer our heads in 2 Stages that will allow you to bolt on up to 55HP.
Our cylinder heads also feature high quality, race proven, stainless steel intake and exhaust valves from Ferrea Racing Components.
Stage 1 (As Cast):
•   326 cfm of airflow
•   Over 48HP Gain!
•   Intake Port Volume: 255cc
Stage 2 (CNC Ported):
•   350 cfm of airflow
•   Over 55HP Gain!
•   Intake Port Volume: 270cc
Flow Sheets and Info Here!
« Last Edit: March 05, 2013, 08:10:09 PM by Ryan@BallisticSpeedParts »
Offline cool
Re: Ls3 Small Bore Heads for Ls1 Engines
« Reply #1 on: March 05, 2013, 07:55:53 PM »
I've been seeing a handful of manufacturers making these small bore ls3/l92 style heads. Very cool stuff.
Toss me a free set and i'll plaster a huge "Ballistic Speed Parts" sticker down the side of my car....
  • Moderator
« Reply #2 on: March 05, 2013, 07:56:27 PM »
Our 383 Ls1 with our Stage 2 Ls3 Heads
  • 11.1:1 Compression
  • Factory Ls3 Intake (w/minor cleanup)
  • Full Exhaust
SAE: 516hp/458tq
STD: 530hp/470tq
[/list]
  • Moderator
« Reply #3 on: March 05, 2013, 08:03:51 PM »
Haha...I'd love to man!!
Yeah there is not many options for this setup, the GM version only flows about 280 cfm and the Mast version is $$$, so we're trying to offer a very powerful and more affordable alternative.
Offline usmcpi
« Reply #4 on: March 05, 2013, 09:52:08 PM »
What cam for the above dyno? Stock ls3 intake?
  • Moderator
« Reply #5 on: March 06, 2013, 07:55:00 AM »
We used a custom spec 248/259.  All of our back to back testing was done with a stock Ls1 block and we used a shelf grind 232/239.  Yes, stock Ls3 intake manifold with some mild cleanup work, we'll probably do some testing with a Fast 102 in the near future.
Offline Sabre002
    • Mazda Motorsports
« Reply #6 on: March 06, 2013, 08:09:20 AM »
I have the CNC LS3 heads from GM the numbers are very close.
What is the combustion chamber size on the head?
Josh
Technical Development, Mazda Motorsports
For info on how to join Mazda Motorsports Team Support Program Email me.
Jsmit295@mazdausa.com
  • Moderator
« Reply #7 on: March 06, 2013, 09:09:32 AM »
Yeah GM's CNC Ls3 head flows well, the GM version I was referring to is their small bore Ls3 head which is as cast only and flows around 280 CFM.
Chamber size starts at 70cc.
Offline Sabre002
    • Mazda Motorsports
« Reply #8 on: March 06, 2013, 09:20:16 AM »
good lord thats huge.  I wish they would cast it smaller so we did not have to mill the heads.
Josh
« Reply #9 on: March 06, 2013, 09:32:00 AM »
Dome that shit
  • Moderator
« Reply #10 on: March 06, 2013, 10:03:20 AM »
Dome that shit
Great answer!!
« Reply #11 on: March 06, 2013, 10:15:36 PM »
Interesting... What would the benefit/power gains as compared to stage 2 243's?
Offline mattster03
  • Dewankling since 2004
« Reply #12 on: March 06, 2013, 11:55:02 PM »
Curious as to this as well.  Has anyone installed these small bore stage 3 heads on a stock displacement cammed engine?
Offline RX7what
« Reply #13 on: March 07, 2013, 12:34:54 AM »
Normal LS3 heads work on an LS2. Why did you mention them in your list? Also did I miss the pricing on these?
PER AUDACIA AD ASTRA
« Reply #14 on: March 07, 2013, 09:13:50 AM »
Less valve shrouding on the 4" bore with these
