holy shit am I the only one that thinks your nuts to spend that kind of money to control a LSX anything?
I think its nuts to put a bunch of money into a car, make big power, and then have a burnout machine.
Don't get me wrong, burnouts are fun, but not the entire way down the track. There is nothing like properly setup traction control on a good ECU. The Honda guys are cutting 1.50 sixty foots and running 8.6's on 24.5" tires. Boost by gear and traction control are what is making that possible. Also, the fail safe features on these standalones when properly setup can save your motor if it goes lean, loses oil pressure, etc. If that saves your motor once then that standalone has paid for itself. The problem with most standalone ECU's is that they are only as good as the person behind the keyboard. If your tuner doesn't know what he is doing then it doesn't matter what engine management you have, you car is going to run like shit. The new Infinity box is badass as is the Pro EFI, Motec, etc. You can't go wrong with any of them. Just pick one your tuner is familiar/comfortable with.
Yep, yep, and yep. These are the reasons folks spend $$ for a standalone ECU.
I just got quoted about $4500(includes 8.35% sales tax) for a proEFI and all the good stuff for boost and flex fuel, does not include install or tuning. Gotta pay alot for all of these features, alot. This setup will allow the ECU to control boost, traction control, flex fuel, fuel pressure compensation, closed loop AFR under all conditions, speed density so no MAF required, etc, etc. If I add N2O later I only need to add a nitrous pressure sensor.
My LS1 ECU has never been great controlling idle, proEFI will make that cake. Looking at Fuelab Prodigy fuel pump to replace my 044, trying to make 650-750rwhp with rear mount turbo on E85 and then spray nitrous when needed. The proEFI can control the fuel pump speed based on fuel need, another nice feature. May repurpose my boost-a-pump to control voltage to ECU/coils, constant 14-15volts should mean strong spark relative to the 13-13.5volts put out by my alternator.
As stated above, my tuner will setup the boost and traction control to optimize launch and acceleration, can even thro in nitrous at launch or anywhere else for some extra punch. With both boost and spray, and flex fuel, and traction control, and and ... having the proEFI or equivalent starts to makes sense, it can control your water inj or water/meth inj as well. I currently have the stock ecu, a progressive n2o controller, rpm window switch and I run retarded timing all the time to be safe for those moments I want to spray. Adding boost ontop with the stock ECU is a time bomb, and as E85 blend changes so does my tune's relation to optimum, always watching the wideband when spraying, gets old, real old real quick.
Haven't pulled the trigger yet, it's alot of money for the added hp but I am guessing the boosted route that always makes the big power will be more fun than a built motor on a huge nitrous shot that only makes the power when spraying. But when the rear end fails it will be more money to install a 8.8 live axle, when stock bottom end fails more money for built motor, yada yada, maybe I should just sell it when I get it into the 10's on the existing setup? Did I say it was alot of $$$?
