January 24, 2021, 06:16:47 AM
Author Topic: Can you get tremec t56 parts  (Read 2295 times)
Offline babillaracing
« on: December 02, 2012, 08:24:41 AM »
Hi you doing sir, i just wonder if you can get tremec t56 parts? if you do please let me know.Thanks.........Omar
  • Moderator
Re: Can you get tremec t56 parts
« Reply #1 on: December 02, 2012, 05:50:05 PM »
LMK what you need.  I can get any parts, any transmission for the most part including clutch kits, slave cylinders, etc.
« Reply #2 on: December 02, 2012, 06:07:27 PM »
cool ,here i go lol
TUFP5211  ssr main shaft 32 spline
89059986  ssr tail housing (gm)
TURA 5203 half ring syncro washer (2)
TURA 5202  outer ring washer retainer
1386-100-007 Tremec F-body Shift rail
1386-014-008 Tremec Shift guide plate
1386-156-004 Tremec detent spring
1386-109-003 Tremec detent ball
1386-098-025 Tremec offset lever
1386-098-016 Tremec Shifter offset lever
1351-183-001 Tremec Shifter bolts (M8x1.25) (4)
89060072 GM 1pc Countershaft w/MM6 gear set
1386-039-001 Tremec Shift guide inspection plate
1332-043-004 Tremec Roll pins 3/16x13/16
TURA4960 Tremec 1pc Countershaft 6th gear thrust washer
1386-193-004 Tremec 1pc Countershaft 5th gear thrust washer
AA20-070-009 Tremec 1pc Countershaft Reverse splined drive gear
TUEN4961 Tremec 5th drive gear for 1pc Countershaft
TUEN4962 Tremec 6th drive gear for 1pc Countershaft
AA20-139-011 Tremec Snap-Ring for splined Reverse gear
Thanks in advance.................Omar
