January 28, 2020, 12:02:49 PM
Author Topic: Fd lsx tt slow build  (Read 68882 times)
Offline babillaracing
Re: Fd lsx tt slow build
« Reply #570 on: July 09, 2019, 12:52:18 PM »
almost done with trans mount (order the ds from pst) when i get the ds i will weld the brace for the ds loop and send it out to powder coat it
braces with nuts weld on that way you dont need to pull carpet for removal and install (have both set ups now t56 magnum  and 4l80e brace mounts)
also order hotwater lab headlights
« Reply #571 on: July 14, 2019, 11:58:23 AM »
Hotwater lab goodies
« Reply #572 on: July 15, 2019, 09:33:17 PM »
finding clutch pressure sensor position
converting rhd to lhd brake pedal
little paint
manifolds cerakote
Online shainiac
« Reply #573 on: July 16, 2019, 10:45:27 AM »
Those headers look badass! Are you still going to be able to run plug wires from the rocker covers or are you going to run wires from underneath
'88 TII -  SBE 5.3L, Twin EFR 6758s, T56 Magnum, Ronin 8.8" IRS, MS3Pro Ultimate
716whp/662wtq @1.3bar
« Reply #574 on: July 16, 2019, 01:50:15 PM »
Thank you sir, yes everything stock
« Reply #575 on: July 16, 2019, 05:51:46 PM »
brake pedal done (inser ocd here, got to do something about all that rust on the steering tube)
c6 z06 app pedal (making the bracket
making the template
mounted but with the leg with the stock curve
now straight
end up doing a reinforcement cause i saw the firewall moving a little
« Reply #576 on: July 16, 2019, 09:28:08 PM »
Progress looks good, the little details now!
« Reply #577 on: July 17, 2019, 08:02:37 AM »
Thanks Blake is getting closer , still a shit load of stuff to do but to help me stay organized i wrote it down and i am trying to do  2 to 4 task a week
« Reply #578 on: August 14, 2019, 08:12:04 PM »
installing cooler brackets
tight but fit like a glove
remaking radiator mount due need it more space for the intercooler piping
easy acces onve the radiator and condenser get remove
turbo and radiator
radiator tabs coolant pressure sensor and closing original filler neck
« Reply #579 on: August 14, 2019, 08:25:01 PM »
Second to last picture - looks like you have a cracked weld in the upper right, whatever is welded behind the coolant pressure sensor.  Make sure you leak test the radiator before you start it up, too.  Usually just filling with water is good enough - I use a red marker around the welds to watch for bleeds.  It's REALLY easy on these stamped end tanks to get pinhole leaks at the slightest bit of cold lap or craters.
« Reply #580 on: August 14, 2019, 08:27:53 PM »
Thanks man for point it out i will double check tomorrow
« Reply #581 on: August 15, 2019, 05:15:24 PM »
today task was install sensors and fuel lines
proefi oil pressure sensor
proefi 5bar map sensor
proefi fuel pressure sensor
proefi clutch pressure sensor
new intake gaskets
cut the firewall lip a little bit to clear the fuel lines
looking more like an engine bay lol
« Reply #582 on: August 20, 2019, 02:23:47 PM »
following the knowledge people here i swapped the ls1 starter for the truck starter
checking intake pipe fitment
« Last Edit: August 20, 2019, 02:42:43 PM by babillaracing »
« Reply #583 on: August 21, 2019, 01:19:20 PM »
Wow what a lot of work!  Will be so exciting to fire it up!
« Reply #584 on: August 21, 2019, 01:28:37 PM »
Thank you sir have been a 7 years on going project on and off sometimes i get burn up and stop for couple of months
