March 23, 2019, 12:21:56 PM
Author Topic: FD 4-point roll bar  (Read 37225 times)
Offline justinsamberg
  • Moderator
FD 4-point roll bar
« on: September 20, 2012, 04:22:55 PM »
Where working on this simple street roll bar for you guys. Its going to use 1 3/4" .083 wall chromoly tubing with a strut tower brace/harness bar. It will also have a V-type bolt in brace to help triangulate the hoop since were going to leave it open.
« Last Edit: January 20, 2015, 01:29:55 AM by justinsamberg »
http://www.rx7v8.com/
Pleasant Hill, CA
justinsamberg@gmail.com
925-484-5800
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
Re: FD 4-point roll bar
« Reply #1 on: September 20, 2012, 04:37:23 PM »
how does it fit to the floor I"m looking for something that goes through the bins to the cross floor brace.
Josh
Stig's sunglass wearing American cousin
74 MGB GT V8 12.83 (75 shot)
93 402 LS2/T56 Rule 3 No V8 RX7's
  • Moderator
« Reply #2 on: September 20, 2012, 04:46:56 PM »
It ataches to the floor pans. Im going to start on a 6-point NHRA legal bar here pretty soon. This just the inexpensive street version.
Pleasant Hill, CA
925-484-5800
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #3 on: September 20, 2012, 07:06:47 PM »
I'm looking for a SCCA 4 point.
Josh
Offline 7StarrsSin
  • Under Construction
« Reply #4 on: September 20, 2012, 09:33:32 PM »
Im in! What's the price range?
:drive: :poke: :gruffy:
Online wickedrx7
FD 4-point roll bar
« Reply #5 on: September 20, 2012, 10:56:05 PM »
Looks good. I would make sure it has nice provisions for harnesses and also the stock cargo cover. Are you going to use floor plates on the main hoop?
  • Moderator
« Reply #6 on: September 20, 2012, 11:23:05 PM »
I'm tring to do the 4-Point for under $1000 in chromoly.
I think all we would need is a diagonal through the hoop to make it legal. Plus it needs to be made from 1 3/4 .125 wall tubing. I plan on making them all out of 1 3/4 .083 wall chromoly.
It has 1 bung for a y-harness but two more could be added for the H-harness.  The floor plates are 6X6" top an bottom.
Pleasant Hill, CA
925-484-5800
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #7 on: September 20, 2012, 11:27:47 PM »
I will look up the rules but I was sure it was 1.5" and 0.125 wall.  I think at 1.75 it could be 0.080 if it was CM.
Josh
« Reply #8 on: September 20, 2012, 11:30:50 PM »
Wow, really nice looking setup there.
2013 Focus ST3 - Stage 1 BPU
  • Moderator
« Reply #9 on: September 20, 2012, 11:34:11 PM »
The rule may have changed since I last looked. I always remember that they didnt care if it was 4130 or not. It still needed to be .125 wall and the diameter was determined by the weight of the car. That was also an IT cage as well.
Pleasant Hill, CA
925-484-5800
Offline Standing Z
« Reply #10 on: September 21, 2012, 08:36:02 AM »
In order to comply with NASA (2500-3000 lb cars) and SCCA (1500 lbs and over) rules, The tube would need to be either:
1.500 x 0.120 Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM
1.750 x 0.095 Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM
Doesnt matter if it's Chromoly or Mild Steel
Why not change your tubing size up from .083 to .095 to match these rules? Then you have a street and a race cage all in one package.
Offline Pez
« Reply #11 on: September 21, 2012, 09:42:36 AM »
Last time I built an SCCA legal cage, the rules said that the rear diagonals had to connect to the rear floor board, not the strut towers. Rules may have changed tho.  FYI.
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #12 on: September 21, 2012, 12:43:40 PM »
I know the race shop one got signed off by the SCCA.
Josh
  • Moderator
« Reply #13 on: September 21, 2012, 01:43:47 PM »
The bar in my pics is 1 5/8" .125 wall Dom.  Thanks for clearing that up. I will go to an .095 wall then. I'll do something different on the 6 point one.
Pleasant Hill, CA
925-484-5800
  • Moderator
« Reply #14 on: September 21, 2012, 02:05:53 PM »
The diagnol we put in are to help keep the hoop from laying over from a side impact. We want to leave the diagonal out at the main hoop because it keeps the passenger seat from sliding back. I am going to offer it as an option though.
Pleasant Hill, CA
925-484-5800
