May 16, 2024, 04:38:15 AM
Author Topic: Clutch Hyd. - Wilwood Master/GM to AN fitting  (Read 7898 times)
Offline Aaron Venable
« on: June 18, 2010, 03:16:15 PM »
Per request,  some pictures of the clutch hydraulic setup I've previously listed P/N's and prices for.
These are the best pictures I have at the moment.
Line is 36" -3 AN to 10mm straight banjo
Russel GM to AN fitting
Wilwood Universal 7/8 bore
Install and bleed from the top.
Re: Clutch Hyd. - Wilwood Master/GM to AN fitting
« Reply #1 on: June 18, 2010, 03:28:53 PM »
From the other thread
Part #'s and Prices
EAR-63010236ERL   -3 ST./BANJO 36 HOSE   26.99
EAR-977503ERL       3/8 BANJO BOLT              4.99
RUS-640281             FITTING                         20.69
WIL-260-3376          MASTER CYLINDER KIT  66.88
Offline ALLslowNOshow
« Reply #2 on: June 18, 2010, 05:22:15 PM »
Here's a pic of mine with the McLeod 48" 4AN line with the built in GM fitting, I forget what the banjo fitting is
« Last Edit: June 18, 2010, 05:27:36 PM by ALLslowNOshow »
86 GXL - LQ9/T56
« Reply #3 on: June 18, 2010, 07:13:28 PM »
Ohhhh that's nice!!!
how much??
Offline lm38330
« Last Edit: June 19, 2010, 10:32:50 PM by lm38330 »
« Reply #5 on: June 20, 2010, 08:58:03 AM »
the one is the second link is what you will need. then purchase a line with a -3AN fitting
OR
just pick up a line like the one posted by Allslownoshow if you want to retain the GM fitting
the only reason I would get a line without the GM fitting would be to reduce the chance of any restriction. I don't know how much restriciton, if any, the GM quick connect has, but I know that my solid line setup has performed flawlessly for the last few years.
« Reply #6 on: June 20, 2010, 12:18:07 PM »
how much??
If I remember right I think it was around $100 for the line and banjo fittings, I had a thread on the old forums about it from a few years ago. Speedway Motors sell the same thing now for less then what I paid.
86 GXL - LQ9/T56
Offline lm38330
« Reply #7 on: June 20, 2010, 12:59:44 PM »
Aaron-i just read the description on the second link.it states that it won't fit the throwout bearing? Any input on that? Any reason why it won't fit,it looks like the russell part
« Reply #8 on: June 24, 2010, 06:06:34 PM »
I didn't scroll down to see that. Looks like it fits the early stuff, and the later master. I don't know what the difference is, but for sure the Russel part fits the later master and slave, plus you a two pack for $20. So the next time you change a clutch and slave, just pop in the new fitting.
$100 is relatively steep compared to the $27 job, but if removing your line from the transmission is a must, looks like the best way to go. If I pull my trans, I always yank it with the engine (it's easier on my car) and just disconnect at the master with zero issues... just something to think about.
Offline smackhead999
« Reply #9 on: June 25, 2010, 02:33:46 AM »
Aaron: what hydraulic throwout is that, that you are using.
Bare bones and ugly
Offline AHarada
« Reply #10 on: June 25, 2010, 11:12:57 PM »
Thanks for posting the Pt. #'s, I got them all from Summit.  How do I remove the GM quick disconnect from the slave cylinder?  Do I just punch out the lock pin and pop it out?
[smg id=6954]
Offline lm38330
« Reply #11 on: June 26, 2010, 12:02:11 AM »
Hey AHarada,let me know how you do it.I have to do mine as well.I was thinking I would have to drop the tranny and remove the locking pin.I'm gonna try and do that as soon as I receive the parts as well.
Thanks
Offline AHarada
« Reply #12 on: June 26, 2010, 04:59:07 AM »
Did it tonight.  Punch out the locking pin, and the GM quick disconnect will slide out.  Insert the new fitting and replace the locking pin.  Very easy.
[smg id=6954]
