June 20, 2019, 06:57:40 AM
Author Topic: SOB Racing 87 with a 4G63  (Read 46369 times)
Offline 1320king
Re: SOB Racing 87 with a 4G63
« Reply #30 on: May 25, 2012, 09:35:11 PM »
that would be him  :)
Offline SOB Racing
« Reply #31 on: May 25, 2012, 09:51:58 PM »
Nice guy, I was emailinghim back in forth about his T5 bellhousing kit.   UntilI found outthat t5's don't like tshift above 6000 rpm.
1985 944 Pending a 4g63T Swap
1992 Eagle Talon TSI Retired
12.27 @ 111 on 14B
12.27 @ 113.9 on Small !6g
2006 HHR "The Hearse" Lowered
Offline 1320king
« Reply #32 on: May 25, 2012, 11:04:54 PM »
deff a good guy, got a subaru ej series with r154 in the works at my buddies shop. Hes building a drift car out of an old impreza. should be intresting!!
Offline N2v8fcs
« Reply #33 on: May 26, 2012, 04:36:21 PM »
 :scratch:what ?
I take mine up to 6300 every drag pass .
:drive:
Offline sciff5
« Reply #34 on: May 26, 2012, 05:00:40 PM »
 :scratch:what ?
Yeah but a lot of 4bangers rev to 8-9k easy so... it's a bit outside the range the t5 was designed for
Offline N2v8fcs
« Reply #35 on: May 26, 2012, 06:07:37 PM »
gotcha
:drive:
Offline SOB Racing
« Reply #36 on: May 26, 2012, 06:09:25 PM »
Yep, I'll be shifting at a minimum of 7200...I was told a T56 can shift that high if you build it up.   But i'm not going to spend $2k on a trans.
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #37 on: May 27, 2012, 10:32:21 PM »
Well little fun with plywood this week.   Worked out how to make the aluminum adapter plate without wasting expensive material.  Used metric T-nuts (arrows) so I can actually bolt the motor and trans together in the car to work out any other details and keep the project moving.
Here's the two bolted together.  Hopefully tomorrow I'll bolt the trans back into the car and then drop the engine in and see where to go next.
I'll eventually trim the wood to match the bellhousing and then use it as a pattern to use with carbide bit in a router on the actual AL plate.
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #38 on: June 12, 2012, 01:39:27 PM »
Time for an update
Fabbed up the right and left engine mounts using some corvette style pedistile rubber mounts. Still need to finish weld them and grind them.
Engine as it sits
Plenum mocked up for clearance. Need to shorten the runners some more to gain TB clearance with the hood.
Oil Pan clearance. Since the stock pan is a front sump design I am going to have to fabricate a rear sump and pickup. Going to do it in steel first and them look at aluminum later.
Doing a clearance check with the hood, it looks like the engine cams will be popping through. So I either have to modify the stock Turbo hood scoop or put a cowl hood on her.
I was checking the driveshaft angles.   I set the engine up with 2 degree's down and my rear differential points up 3.5 degrees??   Does that seem correct for a TII rear diff or are the mount worn?   I don't see any adjustment to set pinion angle so anyone got any ideas here?
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #39 on: June 26, 2012, 10:57:22 PM »
Got some work done.
Got the beginning of my 3" downpipe started. I need to pick up some more 3" pipe to run along side of the axle.
Finished cutting out the 3/16" flange for the rear sump oil pan. Need to start making the carboard template for the sheet metal and start on the new sump pickup.
Picked up a aluminum no-turbo (no scoop) RX7 hood so I can cut it up and see how much of a "bulge" it needs.  I might be able to graft a stock DSM hood bulge for a little steathier look.
12.27 @ 111 on 14B
« Reply #40 on: June 28, 2012, 02:51:32 PM »
looking good man!
Offline screamin88
« Reply #41 on: June 28, 2012, 04:41:14 PM »
I love this build! Keep it up!  :bacon:
Offline N2v8fcs
« Reply #42 on: June 29, 2012, 04:13:07 PM »
awesome work !
:drive:
Offline SOB Racing
« Reply #43 on: July 28, 2012, 10:01:05 PM »
Little update.  Been traveling alot for work but I got some work done.    Fabbed up a new relocated alternator mount to move the alterantor fron the normal passenger side t the driver side.    Got the beginning of the lower radiator pipe made and need to find a rubber hose to connect.
Buddy of mine let me borrow his Miller 175 and spool gun so I've been learned to weld aluminum for my radiator/intercooler mount.   Just need to finish the upper tie bars and get my CXRacing intercooler in next week to get some mounting tabs made.
12.27 @ 111 on 14B
Offline uummm
  • Pre-Staging
« Reply #44 on: December 06, 2012, 01:27:26 PM »
Just bumping to see if you have made any progress, I'm very interested in your build as this spring I'm about to do a simmilar build.  Also did you use a wide block 4g63 or a narrow block?  I hear the wide block would bolt right to the bell housing you have, but I can get a narrow block for next to free (so an adapter plate will be in my future as well lol).
