June 20, 2019, 07:44:08 AM
Author Topic: SOB Racing 87 with a 4G63  (Read 46373 times)
Offline SOB Racing
« on: April 28, 2012, 11:01:54 PM »
I brought home SOB Racing's new project car. 87 RX7 that the previous owner has swapped in a LS motor into. He pulled the motor/trans/radiator and driveshaft. Set up with aluminum turbo hood, LSD center pumkin from turbo car and 5 bolt lug conversion.
It's no way perfect on the body but it's originally a Nevada car with minimal rust. Interior is in decent shape.
I've got a lot of years running a 92 Eagle Talon but my Talon's body is on it's way out.  I also like running something a little different.
Plan is a 4G63 4 banger with a 16g or 20g turbo.  An adapter plate to get to a B2600 bellhousing and then a Turbo RX7 transmission.
Here's her coming home from Iowa
Interor is decent
Stripped out Engine compartment
Painting up the extra rollers and my mock up block
1985 944 Pending a 4g63T Swap
1992 Eagle Talon TSI Retired
12.27 @ 111 on 14B
12.27 @ 113.9 on Small !6g
2006 HHR "The Hearse" Lowered
Online digitalsolo
Re: SOB Racing 87 with a 4G63
« Reply #1 on: April 28, 2012, 11:20:49 PM »
Cool, seen some pretty gnarly 4G63s over the years.  :)
Offline N2v8fcs
« Reply #2 on: April 28, 2012, 11:24:18 PM »
this should be pretty neat, and light weight .
:drive:
Offline SOB Racing
« Reply #3 on: April 29, 2012, 12:37:27 AM »
Thanks!  I'm guessing about 2500lbs w/o me.
Now I just need to locate a 87-88 B2600 bell housing and a decent Turbo TII trans so I can start mocking up mounts.
12.27 @ 111 on 14B
Offline SOB Racing
« Reply #4 on: April 29, 2012, 09:20:44 PM »
Few things done this weekend. Removed, overflow, washer bottle and wiper bottle to clean and paint. I labeled and removed the harness. This will allow me to prep for paint as well as strip out any unnecessary wiring from the loom. Threw the block in there for the hell of it as well.
I also spent some time in the shed and gathered up all the parts I need to complete the mock up motor. All I need to add is a alternator (have) and a valve cover (not really needed)
12.27 @ 111 on 14B
« Reply #5 on: April 29, 2012, 09:40:40 PM »
i heart 4gs!
get r done
Offline screamin88
« Reply #6 on: April 29, 2012, 10:59:17 PM »
Where are you located? I have a TII trans I'll sell cheap... I am in MN
Offline Sho Amo
  • Smoke Tires Not Drugs
« Reply #7 on: April 30, 2012, 02:11:40 PM »
It think im going to really like this project. Please keep up the updates.
[Sold] '90 GTU LS1/t56
Offline SpendOne
« Reply #8 on: April 30, 2012, 07:33:09 PM »
There was a guy the had a 4g63 in a FC years back. He ran 2 china 50 trims on it from what I remember. Motor had to be mounted with a slight lean for clearence. Car went mid 11's blowing tires off first time out.
Stock 350 block/iron headed/nitrous/93 pump gas junker
melted piston....best of 6.07 1/8  9.57 1/4
Higher compression SBC 406 now
Changed again...Stock turboed LQ4 8.79@154mph SOLD
Offline SOB Racing
« Reply #9 on: April 30, 2012, 07:48:25 PM »
screaming88, you have a PM
My current 4G63 with a 14b (stock turbo) in my 3000lb awd Talon runs low 12's.  This car should come in around 2600 lb and with a slightly bigger turbo should run mid 11's.   Should be fun!
12.27 @ 111 on 14B
Offline screamin88
« Reply #10 on: April 30, 2012, 08:40:41 PM »
It's an 88 TII with 116k ... Good shape other than the shifter collar needs to be fixed.. as far as shipping its up to you on how you want to pay and ship...
Offline SpendOne
« Reply #11 on: May 01, 2012, 04:14:10 PM »
If you put a 20g on it, it would definately roll. My dsm @ 3150lbs went 11.3@123 on a buschur tdo5/o6 20g. This was back in 01-02.
Offline cool
« Reply #12 on: May 01, 2012, 04:25:17 PM »
Screamin88 and SOB - I might be able to bring that trans home with me next week.  If you guys work it out, let me know.  Ill have the service truck so I should be able to find room for it.
Offline screamin88
« Reply #13 on: May 01, 2012, 08:27:31 PM »
That would be awesome.. up to sob... I'm game :)
Offline SOB Racing
« Reply #14 on: May 01, 2012, 09:41:23 PM »
Shoot me a picture from the bellhousing side?   This has the removable bellhousing right?
PM me a price...and I guess I'll owe Cool a beer for delivery if we make something work.  8)
12.27 @ 111 on 14B
