May 28, 2020, 11:33:09 PM
Author Topic: *NEW* T56 Magnum (TR6060) 6speeds for sale! $3195  (Read 64197 times)
Online largeorangefont
  • I steer with the gas pedal.
Re: *NEW* T56 Magnum (TR6060) 6speeds for sale! $3195
« Reply #135 on: September 17, 2019, 07:17:46 PM »
Also the description and pictures on the Grannas site seems to indicate it comes with a shifter. That is nice, but i'll reserve judgement until I try it. I may end up reusing my existing shifter.
« Reply #136 on: September 17, 2019, 08:24:16 PM »
I thought the close ratio Magnum had a much taller first gear, as well as shorter fifth and sixth.
The wide ratio magnum has the shorter 1-3 (GTO and CTSV) and same 5th and 6th as the original F body
2.97, 2.10, 1.46, 1:1, .74, .5
The close ratio magnum as the same 1-3 as the original F body, and the shorter 5th and 6th (GTO & CTSV)
2.66, 1.78, 1.30, 1:1, .80, .63
Original LS1 F Body T56 ratios are
2.66, 1.78, 1.30, 1.00, .74, .5
The shorter 1,2, and 3 gears are not great for our cars. The shorter 5th and 6th are magical for our cars. You could get by with the taller 5th and 6th, but it is not offered with the close ratio 1-3.
So you want the close ratio/2.66 first gear setup.
The only bummer is the order of operations to install it in my FC, as we use a 2 piece transmission yoke with the 8.8 conversion to install the driveshaft.. and that 2 piece trans yoke is not available in a 31 spline output that I can see.
I may just pull the engine, I gotta figure it out.
Well, shoot.  To get any huge benefit from the Magnum swap in 1st-4th I'd have to swap my 3.73 gear to a 3.27.
:banghead:
The shorter 5th-6th would help my top gear from being way too tall though.
I have a TKO-600 with the roadrace gears in my Cobra and I love the ratios.
Has anyone swapped one of those into an FD?
That would probably give a good ratio spread, and would save probably 75 pounds or more of weight.  :bacon:
« Reply #137 on: September 18, 2019, 09:16:55 AM »
:banghead:
What is in your car now and how much power do you make? Everyone under 550 WHP is gonna be be dialed with The F body or close ratio Magnum and 3.55 or 3.73s
  • Moderator
« Reply #138 on: September 18, 2019, 11:04:04 AM »
Appreciate the thumbs up Kinger..... I agree it modernizes the car and simply rips!  The gearing truly is perfect.
......as stated there are a few ratios and IMO this is the only want you want: 2.66, 1.78, 1.30, 1:1, .80, .63
The .75/.50 version simply is too overdriven in 6th and 5th falls out of the powerband much more than .80 does.
Anything under 550-600rwhp n/a should run a 3.55 or 3.73 gear with a 80 to 100 treadwear tire with the above transmission.  We had no issues putting down 595rwhp 440ci n/a setup with 3.73 gears and 275/35/18 Nitto NT01 at the drag strip to run effortless low 10's.  Clearly a drag radial or slick would hook better... but for an all around tire it worked fine.
In my 1200rwhp LS9 turbo FD I run 3.31 gears and 26" tall tire with the 2.66/.80/.63 gearing and it is perfect.
Cobranut-
A TKO600 shifting quality compared to a T56 Magnum is not even in the same league.  Plus even modified TKO600's don't always shift well at high RPM.  For those that have driven both... the T56 Magnum is simply the best choice.  My road race LS7 FD with 520rwhp (10.30@138mph) ran a 3.73 gear and had no issues putting down the power on NT01's.
Update:  payments are rolling in and transmissions will be shipping out by next week.
If you are serious and want one... email me!  norcalmotorsport@gmail.com
I've been selling T56 and T56 Magnum related parts for over 15 years....
« Reply #139 on: September 18, 2019, 11:38:27 AM »
I like the .74/.50, but I run 3.90 gears.
I had my 2.66 magnum built with .74/.50. Was a grip of extra money though.
Off the shelf, 2.66/.63 all day.
« Reply #140 on: September 18, 2019, 11:54:46 AM »
Paid for mine! Easy transaction with Mark!
  • Moderator
« Reply #141 on: September 25, 2019, 10:08:51 AM »
largeorangefont PAID
Turbo95max
Cobranut
paul_3rdgen
DrKarrot
wickedrx7 PAID
SpeedKing
crazy3kgt
gnx7 PAID
jdm91t
NOROTOR (tentative)
Skeltic (tentative)
jwvand02 (tentative)
carlb PAID
silverfd19 (tentative)
Please reach out if you are ready for what we have all been waiting on for 3 years.  The perfect T56 Magnum F style version for our swaps!
Selling your standard T56 should not be an issue.  I get 5 phone calls every day for used ones....  Definitely a market for them.
  • Moderator
« Reply #142 on: October 06, 2019, 12:31:49 PM »
Transmissions are shipping out this week.  Will provide tracking numbers as they are generated.
Thank you for your orders and patience.
« Reply #143 on: October 06, 2019, 04:37:53 PM »
 :gruffy:  :bacon: :gruffy:
  • Moderator
« Reply #144 on: October 08, 2019, 09:27:23 PM »
Looks like some people could potentially have these installed by the weekend :)
Only a handful of retailers in the entire country actually have these in stock.  Summit won't have them for 2 more months!!!!
Step up and make what we have been waiting on.... for over 3 years become a reality!
Offline AHarada
« Reply #145 on: October 08, 2019, 10:56:50 PM »
Dang I've only put like 200 miles on my T56 magnum since I did the swap a few years ago because I've been halfway around the world from my car. I should have waited for this!
Anyway, don't hesitate to order from Mark. Ordering couldn't be easier and cheaper, and the product speaks for itself.
[smg id=6954]
  • Moderator
« Reply #146 on: October 11, 2019, 02:14:43 PM »
Thanks for the props AHARADA!
Shipping out a few more T56 Magnum F style transmissions next week.
« Reply #147 on: October 15, 2019, 02:32:51 PM »
Mine was delivered! I need to pick it up and find time to slam it in!
« Reply #148 on: October 18, 2019, 06:52:22 PM »
[ Guests cannot view attachments ] Got mine today!
It shifts like butter just sitting dry in the box!
« Reply #149 on: October 18, 2019, 07:07:31 PM »
It shifts like that in the car too!  Itís amazing!
