March 23, 2019, 12:22:01 PM
Author Topic: *NEW* T56 Magnum (TR6060) 6speeds for sale! $3195  (Read 50700 times)
Offline RawrX8
Re: *NEW* T56 Magnum (TR6060) 6speeds for sale! $2895
« Reply #30 on: August 08, 2012, 08:40:41 PM »
SIKKY shifter for T56 Magnum. Transmission brace is not installed; ref build thread. Virgin transmission tunnel. Samberg subframe, Quicktime bellhousing.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline karsty
« Reply #31 on: August 09, 2012, 11:37:44 AM »
nm, will post in RawrX8's build thread.
  • Moderator
« Reply #32 on: August 15, 2012, 05:22:37 PM »
comparison pics of Fbody T56 to the new T56 Magnum.  I put the front bearing plates (where the bellhousing bolts to) at approximately the same side by side distance.  The difference you will see is in the shifter location and tailshaft length.
  • Moderator
« Reply #33 on: August 15, 2012, 05:25:24 PM »
Also comparison pictures of a 2010 Camaro TR6060 (remote shifter) vs. T56 Magnum (red shifter on it) vs. Fbody T56 (no shifter on it)
Offline karsty
« Reply #34 on: August 15, 2012, 06:16:14 PM »
It's hard to tell in the pics, but is the support member mount in the same place(T56 vs Magnum)?  Same mount style?  Can you take a picture low down and from the back of the transmissions?
  • Moderator
« Reply #35 on: August 17, 2012, 02:12:40 PM »
The shifter needs to come back a good 3-4 inches.
Offline RawrX8
« Reply #36 on: August 17, 2012, 03:46:28 PM »
Looks exactly how mine was sitting. Curious to know what shifter you will go with Mark.
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline karsty
« Reply #37 on: August 17, 2012, 03:57:54 PM »
Isnt the SIKKY shifter the only option?
Offline Jordan Innovations
    • Jordan Innovations
« Reply #38 on: August 17, 2012, 07:01:42 PM »
There have been a couple issues with their first ones, don't know how ready they are.
  • Moderator
« Reply #39 on: August 17, 2012, 08:23:10 PM »
I'm going to go with the shifter my Tremec distributor offers shown on reply #17.  One should arrive Monday or Tuesday to see how it works out.  The linkage that moves it back 3-4 inches isn't shown in the picture!
BTW- The T56 Magnum's casting provision for the mount is about 2" closer towards the engine.  I am running the Samberg Fabrication mount and stock T56 Energy Suspension poly bushing which isn't dependent upon location as it is more of a universal location design.  Hinsons relies upon the stock FD trans mounting locations and won't work on a Magnum.
Straight forward install aside from that.
« Last Edit: August 18, 2012, 12:14:26 PM by gnx7 »
« Reply #40 on: August 17, 2012, 09:03:23 PM »
I like that idea a lot more!  Hopefully your Tremec guy has a good setup for a good price.
BTW- The T56 Magnum's casting provision for the mount is about 2" closer towards the engine.  I am running the Samberg Fabrication mount which isn't dependant upon location as it is more of a universal location design.  Hinsons relies upon the stock location and won't work on a Magnum.
Does the Magnum have mounting provisions for the stock-style T56 mount, or the TR6060-style mount?  We made an adapter here for the TR6060 mount/isolator to go into the Samberg chassis mount hole, can probably make another one for ya until Justin makes a TR6060-compatible mount plate.
Offline RawrX8
« Reply #41 on: August 18, 2012, 11:27:09 PM »
I haven't seen any problems with my sikky shifter. But then I'm far from driving my car. What have you heard?
07' RX8 daily
92' RX7 rhd efini
90' MIATA
02' 748R
Offline lane_change
« Reply #42 on: August 22, 2012, 02:34:30 PM »
Any more info on the Tremec shifter and it's function or positioning?
  • Moderator
« Reply #43 on: August 25, 2012, 11:41:13 PM »
I'm still waiting on the shifter myself.  He was out of town promoting for Tremec at various events and is sending one to me this week supposedly.
  • Moderator
« Reply #44 on: September 01, 2012, 02:37:25 PM »
So I put the T56 Magnum into my FD which originally had an Fbody T56 and the rubber trans mount locations are identical.  I'm running an Energy Suspension universal GM polyeurathane mount on it.
I didn't even need to redrill the holes in the floor for the Samberg steel trans mount itself.   They went back exactly like before!  The only difference seems to be the tailshaft length now and 31 spline output shaft.
Still waiting on this shifter to arrive.
