January 22, 2020, 09:55:59 AM
Author Topic: fox body 8.8 conversion  (Read 38911 times)
Offline justinsamberg
  • Moderator
  • 925 212 5542
Re: fox body 8.8 conversion
« Reply #15 on: March 10, 2012, 01:07:11 PM »
when is this going to be available?
We just need to make the jigs to hold all this stuff together when it's being welded and make some small changes. We should be ready by the end of march. So if your serous I would start looking for an axle housing. Just know that we need the brake line and the bracket that holds the line to the diff as we shorten it and re flare it to makit work with your fd brake hoses.
What's the camber gain like with that setup?  Wait...  :yay:
Pinion gain more like. In a couple weeks were going to pull it out and put it in Ls1fd's car. Right the pinion is at 3 deg. In relation to the ground. Im going to mess with the angle until we get the perfect launch. I'm also going to put some adjustable links on the sway bar so we can tune some weight into the car from right to left so if the car breaks loose we can keep it going straight.
Looks very good, complete, and well thought out.  Like Daniel said, the fact that it looks stock and can lift the fronts is great :)
Pleasant Hill, CA
justinsamberg@gmail.com
925-212-5542
« Reply #16 on: March 10, 2012, 01:13:09 PM »
nice job Justin!  Looks like there is finally a solution for a true bolt in solid FD axle setup.
Is Mike (LS1-FD) going to be the 1st tester with his 950rwhp+ LS9 turbo FD?
  • Moderator
  • 925 212 5542
« Reply #17 on: March 10, 2012, 02:42:44 PM »
mike will be the first. Denny is also getting one. I don't know what name he goes by?
This is what the housing should look like before you guys ship it to me.
« Last Edit: March 10, 2012, 03:12:49 PM by justinsamberg »
Pleasant Hill, CA
925-212-5542
Offline HXMan
« Reply #18 on: March 10, 2012, 09:05:31 PM »
Oh I am going to start looking, I'm on my second FD differential, and it is starting to make noise.  What kinda pricing are you expecting?
So as I understand it we would have to provide the housing, you would then provide the axles and everything to mount it.  I would just have to install the diff and a new drive shaft.
I'm thinking about trying to find a new replacement brake lines...I wouldn't want to use crusty original lines.
94 RX7 w/LS2 Swap
ASE Master Technician
Offline 69bluess
« Reply #19 on: March 10, 2012, 11:04:46 PM »
interested in pricing and seeing some track results of this also :drive:
Offline lane_change
« Reply #20 on: March 11, 2012, 10:10:08 AM »
Interested in how big of a tire you can run under the stock body with this setup....what does "widest tire possible" mean?  315?  335?
Offline mefarri
  • Ye Olde OCD Woodshop
« Reply #21 on: March 11, 2012, 12:41:21 PM »
Probably 315.  Kevin Doe has 315 hoosiers and it's so tight it rubs the inner fender well slightly even after clearancing with a hammer.
-Jimlab
-Blake motherfucking McBride
  • Moderator
  • 925 212 5542
« Reply #22 on: March 11, 2012, 12:59:04 PM »
It means the lowwer radius rods are not the limiting factor anymore.
« Last Edit: March 11, 2012, 02:02:31 PM by justinsamberg »
Pleasant Hill, CA
925-212-5542
Offline rex7fd
« Reply #23 on: March 11, 2012, 01:47:40 PM »
Another game changer from Samberg.
94 FD/2002 LS6, 228/230 Comp Cam,  With Comp Cam everything,  Atomic Rex 360mm 6 pot frontsx 330mm 4 pots rears, Samberg everything, ARP everything,ported Lingenfelter TB, Ram twin plate. Nor Cal AG T-56. RUNNING!!!!!!!!!!!!!!!!!!!!!! 390whp/390tq
Offline WannaBeFast
  • Single and Looking
« Reply #24 on: March 11, 2012, 02:45:24 PM »
This is by far the best.
Another  :poke: bump for FC setup now.  :bacon:
Offline Ls1-fd
« Reply #25 on: March 11, 2012, 03:13:03 PM »
I plan to test this new set up on my car soon.  This set up will cost less than 8.8 IRS swap.
Mike
Turbo LS9 RX7
Offline twokrx7
« Reply #26 on: March 11, 2012, 03:34:10 PM »
Hell yes, we've been waiting for this, rock on Justin  :cheers:
We appreciate the folks ready to test this new solution, you guys rock too  :drive:
07 Jeep SRT8 426 mid-mount turbo, 1100+awhp
14 OBM Blue CTSV sedan, 680rwhp
Offline lane_change
« Reply #27 on: March 11, 2012, 10:29:53 PM »
Mike
Sounds like a plan right there.  Kyle and I did some looking around and I'm digging the simplicity of the setup....just need to see you install it, beat the hell out of it, and give us all the thumbs up.  I'm ready to buy one once it's been proven.
  • Moderator
  • 925 212 5542
« Reply #28 on: March 12, 2012, 02:35:13 PM »
I drove the car again this morning and the rear seems to be getting quieter. It has a brand new set of 330's made by motive gear and the track lock is also new. I think the gears just need to break in and I only have about 5 miles on the rear so far.
Pleasant Hill, CA
925-212-5542
Offline RX7what
« Reply #29 on: March 12, 2012, 10:43:38 PM »
What years can we get a rear axle out of?
PER AUDACIA AD ASTRA
95 FD #496/499 LS2   http://www.norotors.com/index.php?topic=4789.0
Norotors is far and away the best car forum on the Internet, bar none.
