January 22, 2020, 09:31:08 AM
Author Topic: fox body 8.8 conversion  (Read 38910 times)
Offline Jarhead Steve
Re: fox body 8.8 conversion
« Reply #45 on: March 14, 2012, 06:04:29 PM »
needs lower offset/wider wheels  :D
88 528e-DD
http://www.carclubvt.com/
Offline justinsamberg
  • Moderator
  • 925 212 5542
« Reply #46 on: March 14, 2012, 06:55:26 PM »
You mean more offset, right? Im doing another one with 3/8" more offset which is the max you can go with stock wheels.
Pleasant Hill, CA
justinsamberg@gmail.com
925-212-5542
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #47 on: March 14, 2012, 07:11:11 PM »
cant wait to see a FD on the back bumper.
Josh
Stig's sunglass wearing American cousin
74 MGB GT V8 12.83 (75 shot)
93 402 LS2/T56 Rule 3 No V8 RX7's
« Reply #48 on: March 14, 2012, 07:16:06 PM »
higher offset moves the wheels inward  ;)
88 528e-DD
  • Moderator
  • 925 212 5542
« Reply #49 on: March 14, 2012, 07:24:08 PM »
I see. What do guys think is the most popular off set that people are now running?
Pleasant Hill, CA
925-212-5542
« Reply #50 on: March 14, 2012, 07:30:30 PM »
I think 18x10 +50-ish is what they can fit on stock rolled fenders in the back
Offline Jordan Innovations
    • Jordan Innovations
« Reply #51 on: March 14, 2012, 08:59:05 PM »
That's a really tricky question, but I think most people that will be interested in this conversion will are drag-oriented, meaning higher offset (more inboard) wheels for better clearance on the fenders.  I'd keep it a little further inboard than stock so people with fairly aggressive fitment that buy your kit will still be able to use their same wheels.
Offline kev2769
« Reply #52 on: March 14, 2012, 09:11:51 PM »
Couldnt you just sell the mount kit including the axle ends and shock mount and whatever other parts you might need to make to sell it as a kit so the end user can make the axle width whatever they desire and to also cut down on shipping?
I know it makes good sense to have a complete bolt in kit but do you plan on having other options when purchasing this kit?
« Reply #53 on: March 14, 2012, 10:06:35 PM »
+1
88 528e-DD
Offline lane_change
« Reply #54 on: March 14, 2012, 10:23:48 PM »
Just make sure you can clear a 17x11 with a 315/35/17 Hoosier DR.  That'd be great...m'kay.
Offline mefarri
  • Ye Olde OCD Woodshop
« Reply #55 on: March 14, 2012, 11:02:44 PM »
To just give you a reference point, 10" wheel +38 offset is the practical max allowed in the rear for a 285 with rolled fenders on an IRS FD.  I'd agree I would set it a little more inward to allow for a more drag oriented setup.  Kevin Doe has 315 Hoosiers on his rear stock body but it required coilover modification, inner fender well pounding and a super heavy fender roll.
-Jimlab
-Blake motherfucking McBride
Offline RX7what
« Reply #56 on: March 15, 2012, 12:37:50 AM »
Actually Kevin did a very light fender roll. And I would consider 315 to be the largest tire you can fit, 285's fit with lots of room to spare.
PER AUDACIA AD ASTRA
Offline mefarri
« Reply #57 on: March 15, 2012, 12:58:13 AM »
No, his roll was flat/as far as he could.  He didn't pull the fender.  There's a difference.  Also, lots of room to spare is a loaded statement.  In an IRS car you have to replace the trailing arms with fully offset versions to go bigger than a 285/295.
-Jimlab
Offline RX7what
« Reply #58 on: March 15, 2012, 01:07:44 AM »
Depending on your offset. I wouldn't consider rolling the lip flat to be a extreme roll. That's just a normal roll. I did a small pull and still don't consider it extreme.
Offset control arms arnt a big deal either. I'm running nitto 285's and have a large finger between the tire and fender and a good 1/2 inch to the stock control arm. So yeah I would say lots of room to go larger.
  • Moderator
  • 925 212 5542
« Reply #59 on: March 15, 2012, 03:08:07 PM »
To start I'm going to sell it complete. Later on I may break up the kit and sell the subframe and suspension separately.
Pleasant Hill, CA
925-212-5542
