Aaron Matthys
Tampa, FL 33613
Aaron.Matthys@gmail.comMake: Mazda
Model: RX-7
Trim: Base model, black interior
VIN: JM1FD3333R0302045
Price: $16,000 slightly negotiable
NO TRADESMiles on Body: roughly 118k
Miles on Engine: roughly 75k
Reason for selling: Not into cars much anymore. Might as well sell it.
History: 3rd owner. Was originally in Texas for most of its life, then Ohio for a year, now Florida. I did the swap in my garage.
Specs: * Hinson Mounting Kit
* 98 LS1 Block and ECU
* T-56 Transmission
* TSP PRC 5.3L Stage 2.5 Heads
* TSP Torquer v2 Cam 112 LSA
* Cometic .040" Head gasket
* MSD 8.5mm wires and protective boots
* Ported Throttle Body
* 25% Udnerdrive Pulley
* JTR/Sanderson 1 7/8th Long Tube Headers
* LS6 Intake Manifold
* TSP 7.400 Pushrods
* Terra Yella Rockers
* LS7 Lifters
* LS2 Lifter Trays
* LS6 Oil Pump
* NGK TR55 plugs
* 4.10 Torsen Rear End
* Aluminum Driveshaft
* Exhaust: catless custom true dual 3" piping through Magnaflow X-pipe and 5" straight through Magnaflow mufflers
* APR Carbon mirrors
* Japanese R1 Seats
* Nitto NT-01 tires on all 4 corners , stock rims
* Hinson steering kit to adjust power steering level
* Spec Stage 2+ clutch at time of swap (6 puck sprung)
* Mazda Comp aluminium radiator
* Poly Engine, diff, and trans mounts
* Rolled Fenders
* Supra fuel pump and vette FPR
The Bad:* Needs new pillowball bushings
* Cold start and <2k rpm on tune could be smoothed out
* Reverse lights need to be fixed (short somewhere)
* Little wiring cleanup and mount ECU
* No A/C installed, have everything but condensor.
Misc:* Ran a 11.68 @ 124mph with a 1.96 60 foot
* Its a "5-10 foot car". Little blemishes don't show up on camera.
* New Alternator 5k miles ago
* New windshield on Jan 7th 2012 (a chip finally cracked)
* Odometer reset to 0 miles when the battery died. WEIRD.
* Missing ECU plastic cover on passenger side
DON'T HESITATE TO REQUEST ANY PICS/VIDS OR ASK QUESTIONS!Videos:http://youtu.be/xMVL5NwceVshttp://youtu.be/JAynY1LP_C8Pictures (click for full size!!):
