I starting a build thread on LS1 tech then found this site, so I am gonna just copy and paste the good stuff from LS1 tech to here and then add new stuff from there on. I have lots of pics to go with since that is all we want to look at anyways haha.
It's winter up here
The run down so far:
Drivetrain5.3L LM7 from '00 Silverado with 60K Toasted #8 rod bearing journal, looks like debris was the cause
5.3L L33 from '06 Sierra Full refresh after 190K, all new bearings and seals.
MTI Stealth II cam
T56 from '02 Firebird (fresh rebuild)
Ford Explorer 8.8 3.73 with Trac LokGranny's Level 5 8.8 Torque arm
Hooker LS to SBC adapter platesSolid Engine mounts
Trans-Dapt Polyurethane Engine mounts
Modified Truck panNew LS1 F-body oil pan
Heavily Modified Truck Harness
New LS1 Harmonic Balancer
New LS1 water pump
145 amp 2 pin Truck Alternator with
custom low mount F-body bracket
Stock Subfame with added steelFC subframe swap with Ronin LS mounts
Custom Transmission Crossmemeber
CoolingJegs universal Radiator 24x19 #555-52006
Hayden 16" electric fan, no shroud
New LS1 Water pump
Stock Thermostat
Fan programmed for 205* turn-on
Air/fuelWalboro 190 inline pump
Specter 4" cone filter
MAF delete
C5 LS1 Intake Air Bridge
S10 Fuel filter
ExhaustHeadman Block hugger LS headers (looking for better fit)LS3 Camaro Exhaust Manifolds! Perfect FIT!2.5" Stainless duals to Magnaflow Mufflers and turn downs
Photobucket with all of my other pics
http://s784.photobucket.com/albums/yy122/SS-Jon/RX7/Facebook photo album
https://m.facebook.com/3800ss/albums/12174940493/?ref=bookmarkI had a chance to pick up a 2000 5.3L LM7 with harness for $150 so the project just steam rolled from there to trailoring my Project RX7 from my parents farm to Moorhead so I can work on it all the time. I have been doing a bunch of research on this project and sadly there is not much specific info on swapping a Gen III SBC into a First gen RX7 SA or FB. So I am taking info for basic LS swaps and older SBC swaps and RX7 purist pages as well. By purist I mean the types that would gut me and stick my head on a spike for doing this, lol. I had plans of running a newer 13b S5 N/A engine in this car but lost interest a while ago. We all know that V8 power is so much more fun!
Pics of the car as it was sitting for the past few years, the 13b was quickly yanked.
Started test fitting just the engine while I was looking for a transmission, debated both a T5 and T56. After some research I did not want to pay $500 for a T5 that I will end up replacing for sure, so Beefy T56 it had to be!
Fresh from the junk yard $150
Started finding other things to work on while waiting for Transmission. Mounted the stock oil cooler up and forward.
bought some oil cooler lines that fit the LS oil pan
Adapted oil cooler lines to stock lines
Modified truck pan
Removed stock inline pump and filter, mounted in new filter and pump with some high pressure hose and clamps.
Got the engine all ready to go, Hooker engine mounts LS conversion.
Rolled it outside and cleaned it up some
Thats enough pics for the first post...
