i did a quick search but only found out that i can either reduce the pressure or a spring kit. not sure if this is the answer but the problem im having is that my steering is way to sensitive at high speeds. i know something is off cause i did have a 93 once before and was nowhere like this one. little turns left or right pulls really hard.
almost crashed straight into a ditch once. was turning a corner and took it a little faster than i wanted to so i thought i had no choice but to turn the wheel little more and well sure enough thinking it was just a little extra turn out to be alot at the wheel and crazy understeer, broke lose and skidded foward with the wheels turned. then ofcourse once it gripped it shot me into the direction i was pointed and again and again both ways untill it slowed down enough to stop the craziness. haha even worse than realizing that i suck and didnt know what to do. my gf was in the car.
"i meant to do that, i was just trying to scare you alittle". little did she know i had to go home and check my pants. sorry for rambling.
if its possible how do you reduce the pressure?
