Through extensive online searching, guess and check, and a nice, patient employee at O'Reilly Auto Parts I have tracked down a nice fitting set of radiator hoses for an LS1 FC with the JTR C4 Corvette radiator kit.
The LS1 waterpump has a 1 5/16" outlet and a 1 1/2" inlet. The C4 Corvette radiator has 1 5/16" inlet and outlet.
This documentation uses all O'Reillys Auto Parts numbers, prices and links. That being said, using the vehichle description of each hose you should be able to go to whatever auto parts store you have available and source the same part of whatever brand name they carry.
Also, if you want to follow the JTR instructions and put a petcok or steam vent line in the upper hose, the part numbers listed in the JTR install instructions would be just fine for a 2 piece upper hose.
LOWER HOSE:Part #: Gates 23045
Original application: 2005 Chrysler Pacifica 3.8L V6 "Lower" hose
Cost: $15.99
http://www.oreillyauto.com/site/c/detail/GAT0/23045.oap?pt=01358&ppt=C0331This hose has one 1 5/16" end and one 1 1/2" end. Which is just what is needed for the engine/rad combo. In stock form its obviously not even close to fitting. When you trim the ends though, I think it is about as perfect as you are going to get for the application. On the 1 5/16" end you cut one of the bends off right at the end of a short straight section. On the 1 1/2" end you cut maybe an inch or so off.
Stock hose
Ends cut off
Installed in car
Hose clamps for lower hose:Radiator end
1 1/4" I.D. Nominal 1 1/2' - 1 3/4' O.D. Powergrip Hose Clamp
Part #: Gates 32941
Cost: $4.69
http://www.oreillyauto.com/site/c/detail/GAT0/32941.oap?keyword=32941Water pump end
1 1/2" I.D. Nominal 1 3/4" - 2" O.D. Powergrip Hose Clamp
Part: Gates 32948
Cost: $4.69
http://www.oreillyauto.com/site/c/detail/GAT0/32948.oap?keyword=32948UPPER HOSE:Part #: Gates 22147
Original application: 1993 Mercury Villager 3.0L V6 "Lower" hose
Cost: $17.99
http://www.oreillyauto.com/site/c/detail/GAT0/22147.oap?pt=01358&ppt=C0331This hose has both 1 5/16" ends which is correct for the waterpump outlet and the C4 radiator. Nice fit with just a little cut off each end. Maybe 1" off one end and 3/4" off the other. I might trim it a tiny bit more but that is a pretty good close fit that I am happy with. Plenty of room for the P/S pulley and cooling fan though mine are not mounted in the picture.
Stock hose
Ends cut off
Installed in car
Hose clamps for upper hose:Same size both ends
Part #: Gates 32941
Cost: $4.69
http://www.oreillyauto.com/site/c/detail/GAT0/32941.oap?keyword=32941Both hoses together, both trimmed to fit.
What I really like about these is with a little careful trimming the hoses fit very well with virtually no stress being put on the radiator at all. I didn't want to force a hose to fit and have it result in pulling on and cracking the radiator over time. In the pictures I included with both hoses installed, the radiator is just resting on the lower mounting brackets and not bolted down at all.
So for about $53 you can get both hoses and shrink fit hose clamps for a nice clean setup. Enjoy!
