April 25, 2024, 02:16:44 AM
Author Topic: Why L92 heads rock - 517 rwhp....stock LS2 block!  (Read 41386 times)
Offline Bob H
« on: December 19, 2010, 05:37:31 PM »
So I put this in my build thread -but feel this is worth of its own thread.  Finally got the full tune done on my car yesterday.  Background and parts:
Stock 12k mile LS2 block from TBSS.  Cylinder heads are stock,(untouched runners/chambers), L92 heads shaved down to 64cc's.  The L92 vs the LS3 heads - L92 has the bigger heavier valves,(not machined vs the LS3 valves).
 Cam - custom spec by Patrick G - a "baby" cam by his words.  222/230 .597
Datsun 240Z (2), Big Duramax truck
Offline Heavyfoot
Re: Why L92 heads rock - 517 rwhp....stock LS2 block!
« Reply #1 on: December 19, 2010, 06:04:28 PM »
This is the best ls2/l92 combo i've seen yet. Another one Patrick did a great work on was this http://www.ls1tech.com/forums/dynamometer-results-comparisons/1123842-ls2-l92-heads-makes-460rwhp-446rwtq.html but that doesn't even compare to this. Did you keep the TBSS throttle body or did you swap it out for gto/vette version? we need videos lol.
Offline LPIRacing
« Reply #2 on: December 19, 2010, 06:31:10 PM »
I love the torque curve.  You see so many curves that start at 4500.  For our car the 3250 - 6500 range is very usable.
www.LpiRacing.com
Brakes, Suspension, and Safety
Offline Demon
« Reply #3 on: December 19, 2010, 07:02:40 PM »
That is very nice, you'll love that power curve, its almost a clone to ours!
Offline csilvers1984
« Reply #4 on: December 19, 2010, 08:49:35 PM »
wow! is the power in the heads/intake alone? that is impressive for a milled headed stock block. what the compression on the motor?
Offline GEAUX FAST
« Reply #5 on: December 19, 2010, 09:29:16 PM »
God damn...
Thts a monster, my sc combo better bring the heat!!!
Nice work!!!
Offline GEAUX FAST
« Reply #6 on: December 19, 2010, 09:29:56 PM »
Race gas?
Offline Project10AE
« Reply #7 on: December 19, 2010, 10:13:30 PM »
what type of dyno was this on?
2012 Mazdaspeed3 - some mods  :drive:
1988 Mazda RX-7 10AE - basketcase :scratch:
Offline Bob H
« Reply #8 on: December 20, 2010, 12:30:26 AM »
Ok, answers:  pump gas, Dyno is an eddy current dyno - proven in the past to be pretty accurate,(religious maintenance, calibrations, resetting baro/temp/etc. for every run among other things).
 The throttle body is a LS2 electronic one - GTO/Corvette style.  Intake is the Samberg radiator setup.
 Where is the power?  I think two things - one, shaved heads giving about 11.4:1 compression ratio,(vs about 10.4:1 on unmilled L92's), and the camshaft being spec'd properly for my build.  The intake - basically a stock LS3 intake, in front of the throttle body - very similar to a Camaro setup - a straight shot.
 Honestly - initially we thought something was wrong in the settings for the dyno,(you set the weight/etc..) - it was set for a camaro,(3400 lbs), and when it was reset to 2800lbs, it hardly changed at all.  The best non milled/shaved L92 w/LS2 motor he had done before was about 475rwhp.  So my extra nearly point of compression, the very straight shot intake and a good exhaust setup are likely the difference.  I expected lower than a camaro setup because of a solid axle vs independent rear suspension - bottom line, its one beast of a motor.  Took it out for a drive this afternoon with my dad - no traction in 1-3rd, and it starts getting squirmy in 4th....
 515 rwhp, 2800lbs - about 5.5 lbs/hp.  If you go by flywheel hp,(1.15 correction factor) about 590-600, 4.7 lbs/hp
To put it in perspective - new ZR1: 5.25lb/hp with flywheel of 638 and weight of 3350.
Mclaren F1: 627hp, 2950lb - 4.7lb/hp,(same as mine)
 If you've ever watched videos of the McLaren F1 on the track - and the absolutely brutal accel/spinning/etc.., that is very much what my car is like right now.
« Reply #9 on: December 20, 2010, 12:41:04 AM »
Damn man you have the setup,do you mind disclosing how much you have in the motor? Not counting intake and headers,speaking of headers thats through mids.
Offline RX7what
« Reply #10 on: December 20, 2010, 12:49:22 AM »
I am planning on running LS3 heads and a FAST 102 on my LS2. How did you cut out the center bars on the LS3 manifold? This makes me happy, I have been hoping for around 475whp.
PER AUDACIA AD ASTRA
Offline dream36realms
« Reply #11 on: December 20, 2010, 02:50:52 AM »
Impressive. It is amazing how you got so much more power with the correct parts all coming together. Have fun with her and stay out of first
日までに仕事および夜までに虐殺。
を下って、人類と
Offline ChippeRX7
« Reply #12 on: December 20, 2010, 07:22:28 AM »
not to discount the build at all but have you guys noticed how some motors just make more power given similar states of tune?
That sounds wicked man, glad to see some hard work and money pay off for a change!!!!!
You're so lucky you get to enjoy your car now!!!
1990 GXL 5.0 w/ ported gt40p's and a T-5  ::)  . . . Dont hate me cause im poor :(
UNDER CONSTRUCTION
Offline mefarri
« Reply #13 on: December 20, 2010, 12:49:32 PM »
Nice man.  You need to let me know when you're around Little Rock/Maumelle and take me for a ride.
The L92's come on what engine normally?  The 6 Liter truck engines?
-Jimlab
-Blake motherfucking McBride
V8Mongrel
  • Guest
« Reply #14 on: December 20, 2010, 12:50:16 PM »
6.2L.
