My car started as a track and autocross dedicated 87 Turbo II. In the fall of 2008 my Dad and I found a good deal on a 94 LT-1/T56 out of a Camaro. In the spring of 2009 we also installed a 8.8 IRS out of a Thunderbird. I have 10K miles on the car since including two One Lap of America races in which we won our class both years.
Details:
Granny's Speed shop cradle and transmission mount
94 LT-1 stock bottom end
Llyod Elliot custom cam (224/230 .571/.568 lift 110 LSA)
1.6 Proform full roller rockers
Comp Cams beehive valve springs
Trick flow hardened push rods
58mm throttle body
Accel coil and ignition box
alternator lowered on a custom bracket
Remote oil filter
3qt Canton Accusump
AZ speed ceramic coated 1 3/4" long tube headers
cold air box
electric water pump
Griffin radiator
Fluidyne oil cooler
Jim's Performance modified engine harness and computer
Walbro 255lph fuel pump
8.8 Ford IRS 3.27 gears
88-91 Mazda 929 driver's side axles
custom made stub axles
custom driveshaft
17x8 +40mm offset wheels
5mm spacers on all 4 wheels
225/50 front
255/45 rear
Koni adjustable coil overs
Suspension technique's front adjustable sway bar
Racing Beat adjustable end links (front and rear)
Custom dash
Autometer gauges
Auto Power roll bar
Racequip 5 point harness
Sparco driver's side seat
Race On USA front nose piece
More pictures of the build can be found at the two links in my signature in the blog and album sections.
