this seems to be holding up fine. Have did a few autox's on it, a few road trips and now my t56 is in. So I can really bang on it now.
Thanks,
Bret
This is my setup. I used the sway bar link (dog bone) first and now everything but the front diff mount is still good. I have the mazdacomp rear diff bushings (may, 2015) and the front mazdacomp diff mount (2011, when we boxed it)
I'm now trying to figure out if I want to replace the stock rubber subframe bushings with delrin.
I pulled the delrin wing diff bushings bc of terrible nvh and road noise on Highway trips for shows and autox over 20 minutes away. I'm really trying to keep my car a street car (ac, ps, poly bushings, tein flex with edfc, "street" 200 tw re11a ;-) etc)
Also could I run a solid diff mount from pbm
https://store.partsshopmax.com/shop/FC/SolidBushing/FCSDB.htmlwith the delrin subframe bushings? Or is that going to be too extreme?
http://pages.ebay.com/motors/link/?nav=item.view&id=111814656780&alt=web Or should I stick with the mazdascomp front mount from racing beat and do the pinion snubber and keep the rubber subframe bushings?
Can the Mazdacomp front mount be reinforced at all with welding on it? Is that what some have did? If so does that push back to the full Metal front mount for less and no rubber (but with full Metal it Could rip the subframe right?)
Ugh I'm stuck and need to order new parts and stuff today
Sent from my Nexus 5 using Tapatalk
