I would think that they would fit. The biggest problem is steering shaft clearance and due to the exit location and the flange orientation, it looks like they should clear.You can probably check this site to eventually find out:http://www.motoiq.com/magazine_articles/articletype/categoryview/categoryid/20/project-rx7.aspx
have u checked out edelbrocks they look good and cheap
seems like to me that is the type of discharge that would fit the easiest...IMO
Quote from: matt on May 14, 2010, 06:54:36 AMI would think that they would fit. The biggest problem is steering shaft clearance and due to the exit location and the flange orientation, it looks like they should clear.You can probably check this site to eventually find out:http://www.motoiq.com/magazine_articles/articletype/categoryview/categoryid/20/project-rx7.aspxHah bitchin! I was worried I'd have to bite the bullet and order at least one to test fit.Quote from: overkill-lt1 on May 14, 2010, 11:28:05 AMhave u checked out edelbrocks they look good and cheapThe referee won't dig aftermarket parts. With a stock style exhaust manifold he may even glance over them. No part can be blanket 50 state legal. The EO sticker is only for one vehicle, one year, and one engine combination. It would take some fighting to get the edelbrocks to pass.
It's never a pitty to LSx a FD. It's like giving a homeless guy a job and helping him be a productive member of society.
i have those camaro rear exits on my car atm. they are the same as VE commodore down here.i can confirm that they clear a RHD fine but do point directly at the subframe lower wishbone boxed section.you can get them to work though as i have done!
