Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
April 25, 2024, 12:50:18 PM
Technical Information
Electronics
1993 RX-7 Rear Brake Lights Not Working
Add to Reputation:
I agree
I disagree
Comment:
« previous
next »
Print
Pages: [
1
2
Author
Topic: 1993 RX-7 Rear Brake Lights Not Working (Read 9035 times)
nadeem
Staged
View Gallery
on:
October 10, 2010, 08:09:27 PM »
Question Regarding a 1993 RX-7. All the lights turn on just fine on my car. But when I apply the brakes the rear brake lights do not come on. I noticed that this has just started to happen about a few days ago.
Attached Fuse Box image is from my car. Which Fuse controls the rear brake lights? 1993 Mazda RX-7 Fuse Box
Last Edit: October 10, 2010, 08:12:50 PM by nadeem
Logged
93silverbullet
Supporting Member
Launching!
Faster than a speeding ticket...
View Gallery
Re: 1993 RX-7 Rear Brake Lights Not Working
Reply #1 on:
October 10, 2010, 08:27:32 PM »
It is the 20 AMP fuse on the upper left.
Logged
Richard.
Pez
Top Fuel
View Gallery
Reply #2 on:
October 10, 2010, 08:30:11 PM »
20A. Top left corner.
Logged
nadeem
Staged
View Gallery
Reply #3 on:
October 10, 2010, 08:30:56 PM »
Greg / Richard,
Thank You. The problem cannot be anything else other than a fuse. Correct? It's difficult to get under and up there to remove that fuse.
Last Edit: October 10, 2010, 08:34:17 PM by nadeem
Logged
Pez
Top Fuel
View Gallery
Reply #4 on:
October 10, 2010, 08:31:28 PM »
OOOOOOOOHHHHHHHHHHHHHHH SMACK!!!!!!!!!!!!
Richard in before me on an electrical problem.
Logged
93silverbullet
Supporting Member
Launching!
View Gallery
Reply #5 on:
October 10, 2010, 08:31:56 PM »
Here's a pic:
Close up of Fuse Cover
Last Edit: October 12, 2010, 07:27:22 PM by 93silverbullet
Logged
Richard.
93silverbullet
Supporting Member
Launching!
View Gallery
Reply #6 on:
October 10, 2010, 08:33:12 PM »
Quote from: Pez on October 10, 2010, 08:31:28 PM
Just got lucky... my electrical guru
Logged
Richard.
93silverbullet
Supporting Member
Launching!
View Gallery
Reply #7 on:
October 10, 2010, 08:35:04 PM »
It could be the brake pedal switch gone bad or possibly a bad connection to it. I'd check that after checking the fuse..
Logged
Richard.
Pez
Top Fuel
View Gallery
Reply #8 on:
October 10, 2010, 08:39:04 PM »
Circuit goes, fuse, pedal, lights. Pretty simple. Check for voltage at the fuse, at the pedal, at the pedal with it pressed, and at the lights. You should be able to find where the signal is broken.
Logged
nadeem
Staged
View Gallery
Reply #9 on:
October 10, 2010, 08:44:50 PM »
That's what I did Greg, I pressed the brake pedal and I dont see the brake lights come on.
Here is what I want to attempt - Stop me if I should not do this. In the attached image I will temporarily take the Functional B (Wiper) remove it and install it in A. Just to see if it works.
By the way, is there a fuse removing device. Cant get my fingers around the fuse.
Last Edit: October 10, 2010, 08:46:31 PM by nadeem
Logged
Pez
Top Fuel
View Gallery
Reply #10 on:
October 10, 2010, 09:11:29 PM »
There is a fuse removing device on the inside of your fuse box lid. If not, just use some needle nose plyers.
I don't mean press the pedal and look for lights, I mean check the circuit in different places through out the circuit for 12v with the pedal on and off. The pedal itself should be getting a constant 12v, key on or off.
Logged
nadeem
Staged
View Gallery
Reply #11 on:
October 10, 2010, 09:30:47 PM »
There was never a fuse box lid so I could'nt find the fuse removing device. The entire fuse box is in such an awkward location that it's hard to get under and up there. I tried removing it with my fingers but no go. I'm going to have to get a device from a local WalMart.
Logged
digitalsolo
Administrator
Top Fuel
View Gallery
Reply #12 on:
October 10, 2010, 10:41:12 PM »
Doesn't the TNS relay also control the tails?
BTW, a pair of needle nose pliers is the best thing I've ever seen to remove those fuses. I have little agile fingers and they're still a PITA to get at.
Logged
1988 Mazda RX7 - Turbo LS1/T56/ProEFI/8.8/Not Slow... sold.
Pez
Top Fuel
View Gallery
Reply #13 on:
October 10, 2010, 10:47:20 PM »
TNS controls tails, not brakes.
Logged
clocker
Staged
Because Streetcar!
View Gallery
Reply #14 on:
October 11, 2010, 07:18:16 AM »
TNS= Tail, Numbers (license) & Side, so basically, running lights and interior illumination (gauges and switches).
Now, if I only knew what BTN stood for...
Logged
Print
Pages: [
1
2
« previous
next »
Electronics
