Blown Stock Diff
Cobra diff setup after i blew the stock unit
Car weighs ~2700 at the track
I am looking to get it to ~2600 lol. Thanks for the compliment I am super in love with how the car is coming together.
So here is what I am ordering tomorrow.
Ford 8.8" IRS
Ford inner axle stubs
DSS Axles for the conversion :ballin:
http://www.driveshaftshop.com/pdetail.php?pid=134DSS custom driveshaft
The following are to rebuild the diff:
http://www.summitracing.com/parts/FMS-M-4700-C/http://www.summitracing.com/parts/FMS-M-4413-A/http://www.summitracing.com/parts/FMS-M-4210-B/bushings from these guys
http://www.svtperformance.com/forums/suspension-258/260665-cobra-mustang-irs-delrin-uhmw-alum-bushing-kit-w-adj-sway-bar-links-bumpsteer-kit.htmlSamberg 8.8" cradle
Either 4.10 or 4.30 gears as well. Not sure yet.
Here are some pics from the shop today. Mind you the car is filthy but I know I have been slacking hard on pics since I got it up and running.
Stuff we took apart!
EMPTY!!!
:fu:
LOL at what the inside of the torsen unit is supposed to look like.
Things that were happening:
Entire interior out including dash
Patch holes in firewall and shifter area
Install 24sqft of dynaliner(lightweight sound deadening and thermal barrier)
Delete ABS(no comments or opinions please)
Relocate small battery under the hood where abs was
Make new power and ground cables as well as add a second engine ground(Hopefully eliminating a WOT voltage issue)
Make a rear section out of hardboard and make the car a full interior car
Custom mount a set of Rockford Fosgate 6x8 speakers in the sail panels making it a 4 speaker system.
And here is where we have gotten
All holes have been patched. This is just a few of them and give an example of how big they were. Thats a lot of heat!
A couple dynaliner shots
Note: battery box is gone now!
ABS gone and new battery mounted in place with new cables
A few new lines and I moved the prop valve to the drivers side. Eliminated a ton of lines.
Engine bay shot, starting to look nice. This winter I will be sure to paint it I swear!
Starting to put it all back together
My carpet didn't fit well so I made a 38"x4" patch I glued in. Now it will fold over and give a clean even seam.
Hardboard I will be using to make a full template of the rear hatch area and then insulate and carpet. I want to be able to pull it out easily to put tools and such in the spare tire well.
Can't forget my rice addition of the week, PS im changing the red all to gold and black.
More updates soon, I am really excited to see how much it improves the car when I finish it up.
Some interior pics. Not 100% yet but im working on it. New speakers FTW.
Went out and tossed the strut bar back in and it does look great. Thanks the blue I totally forgot. Second pic is the area I am undecided what to do with and is basically all I need to do to "finish" the interior.
