I recently lost an apex seal on the front rotor. I made a promise to myself long ago and said when this motor goes out, a 1J will go in. That day has come and that day now. For anyone interested in the background of the car, please feel free to check out my build thread on rx7club. I started the thread in 2013.
https://www.rx7club.com/build-threads-292/half-ass-2-whole-ass-1-a-1048550/With moving on to new things with the car, I have made an account on this site as I feel it is more appropriate for this than posting on rx7club. the "other engine swap" section doesn't get much traffic it seems and I don't see there being much help coming from there either. At least here, I feel more its likely that someone with knowledge and experience with this swap/motor will show up and chime in.
I've already started doing stuff so I will get this thread up to speed. I already have a motor and its from a jzx100. The motor is already in the disassembly stage as the head has already been removed and the block is mostly apart. I havent touched the FD yet as far as taking it apart goes. It's still sitting there as it was the night when the apex seal blew. I already have a transmission. I ended up buying 2 R154s: 1 is stock and the other has an OSgiken gear set in it. I still need to make a decision on which i want to use. My plan to stay organized is to focus on 1 thing at a time. Everything head related is going to be taken car of first. So all of the valvetrain and everything that attaches to the head will sorted then i will move on to the block, then the transmission, then the chassis. The deadline I set for myself is to have the car running by August or September at the latest.
Parts list:
Engine- JZX100 1JZ-GTE VVTi
Transmission- R154
Turbo- Turbonetics T67 hybrid something or other i dont remember what the guy said the specs were
Manifold- CXracing. this manifold is going to be modded to not suck as bad
ECU- looking at a power fc d-jetro or an ECU master EMU. havent decided yet
Harness- dr.tweeks whatever whatever plug and play whatever
Swap Kit- KSracing-thailand. if you dont know what kind of baddassery is going on in thailand, look them up. those guys are legit
The plan forward is to upgrade everything that I feel needs upgrading on the motor along with a rebuild while keeping it mostly stock. Nothing will be upgraded internally. Stock bottom and stock head. For my power goals it will be more than sufficient. I'm going for practical and usable power on a street car. It will be very conservative.
At the moment, my next move is to get the head broken down and get it to the machine shop for cleaning and to get the valve stem seals replaced. In reality, getting the head broken down means removing the shims because I don't have the tools to remove the retainers or anything else. So maybe this weekend the thread will be updated with some progress
