I went a different direction with my build (a new forged short block and Mamo top end). So, selling the parts I collected prior to the redirection.
SOLD SOLD Harrop LS3 Hurricane ITB Manifold (DBW) / New - $2,800 shipped SOLD SOLD I was going to use this on a BMW e24 swap project (high performance BMW's have to have ITB's, right? Right). But, that project is on hold while I get back into the FD LS-swap game. I do not believe it will fit in an LS swapped FD without significant modification, probably hood bump or cut of some kind. Drive-by-wire version setup for the early model ETC ("silver" throttle body). It can, as I've been told, also be used with the late model ETC ("gold" throttle body). It has 0 miles, unused.
Does not include fuel injectors (uses 60mm long fuel injectors), AN fittings/hose or air filters. More info:
https://www.harrop.com.au/shop/automotive-performance/engine-components/308-inlet-manifolds/hurricane-manifold-early-etc.
2010 Camaro Water Pump and Front Accessory Kit / All New $755 plus shipping This kit includes everything to convert from the truck accessories to 2010 Camaro LS3 / L99 accessories. Includes:
GM# 19207665 Water Pump
GM# 12617538 Harmonic Balancer
GM# 13501721 Alternator
GM# 12610789 Alternator Mount Bracket
GM# 92229662 Power Steering Pump
GM# 12610794 Power Steering Pulley
GM# 12610792 Power Steering Mount Bracket
GM# 12568996 Idler Pulley
GM# 12628025 Tensioner
GM# 12639280 Serpentine Belt
and... all the hardware/bolts for installation
T-56 Magnum Shifter from Driveline Components Company / New $300 shipped This is the same one Mark/gnx7 sells through his distributor. I picked it up from Mark when I bought a T-56 Magnum from him a couple years ago. I'm installing the Sikky shifter.
----------- SOLD --------------SOLD SOLD 2008 L92 / LS3 6.2 Longblock 35k miles - $2800 plus shipping SOLD SOLD L92 / LS3 - This is out of a 2008 Denali with 35k miles. all aluminum 6.2 liter with LS3 style heads. rated at 403 hp from the factory. It has VVT, but not DOD/active fuel management. popped the valve covers and 1 head off to make sure it everything was good. This is the complete long block with no intake or accessories.
SOLD SOLD Samberg FD Radiator / New from latest group buy $1350 shipped! SOLD SOLD Radiator kit is the LS2 MAF version and includes cold air intake, expansion tank and dual 11″Spal fans #30102022
SOLD SOLD Eaton Detroit TrueTrac 8.8 Limited Slip Differential TT70P52670 / New $380 plus shipping SOLD SOLDFor those of you doing an 8.8 swap, this is a great LSD. It's relatively inexpensive. And, they are tough / maintenance free. This is the unit recommended by the guys at Ronin for their 8.8 conversion kit.
