What's up with all the premium swapped 7's coming out of Mississippi lately?
Definitely sad to see this one go up on the block Josh, but I can absolutely relate to your position.
Out of all the swapped 7s I've seen over the years, yours makes it to my top 5. Your 7 is the only car that makes me feel foolish for moving away from Montego Blue
Knowing mine had $52k+ in parts when I sold it. I can't imagine what you've got in yours.
Wish you the best of luck in selling. Fall may slow things down, but I expect you're still getting some serious bites behind the scenes
Lane
I too want frosty AC and talking to halfspec he said what holds the car back is the (heat exchanger?) inside the car needs a bigger fan or it will just ice over and not move the cold into the cabin.
The
evaporator is the limiting factor for the FD. This statement was made simply to clarify that adding a more efficient compressor (like you were proposing) would do you no good since the evaporator's thermoswitch would stop the compressor once the core's temp approaches freezing (to prevent it from freezing up). The end result is that you'd just be cycling your super compressor on and off a lot more. Actually, if you want to get technical, a more efficient compressor isn't going to net you anything in this application except maybe a lower electrical load. The only solution to this problem is to increase the efficiently of the evaporator. Like XLR8 said, a more efficient refrigerant is solid step in the right direction. Other options would be to increase the size of the evaporator core (not possible without dash modifications) or increase the size / airflow of the blower. All three options would increase the evaporator's cooling capacity.
