<<car is sold>> I've owned this car for almost 10 years, purchased from an ASE Certified Master technician who did the swap. Car has been very well treated since then and **runs and drives wonderfully.**
https://goo.gl/photos/HZ1Bo9WbkgpK8ffD9 Engine and trans are LS1/T56 all stock. Roll bar, Koni Yellows. Long tube jet hot coated JTR headers, Hinson radiator, stock Mazda head unit DVD player. Cats after both headers, and on collecter before exhaust. Looped rack. A/C is plumbed and wired but not charged; it held a charge for a few weeks when I first built the system, but won't hold a charge for more than a few hours now. I'm virtually certain I've got the wrong gasket on the back of the compressor, and that's the problem. I initially got it going when I lived in TX and needed AC, but when I moved to UT I just lost interest in fixing it because it's not "Texas hot" here. The system has functioned *very well and blew very cold* in the past, but will need to be repaired in order to function.
99,600 miles on the car, ~40K miles on the engine before the swap.
Original paint is in good shape.
Love the car and have loved owning it; I'm just not driving it enough. Someone else is sure to get more use out of it! Car is in Utah, buyer to arrange shipping.
$20K
Motor:
'02 Chevrolet 5.7 liter all aluminum LS1 V8
Hinson Supercars LSX/FD3S K-member
JTR long tube headers
Ported MAF
K&N cone filter
Hinson Supercars radiator
Aeromotive Fuel Pressure Regulator
Estimated power: 375hp
Transmission:
Tremec T56 6-speed
Pro 5.0 short shift linkage
Steeda short shift rod
Wilwood master cylinder
Hinson Supercars transmission mounts
Hinson Supercars torque brace
Hinson Supercars aluminum driveshaft
Stock 4.10 RX7 Torsen limited slip rear differential
Brakes:
Mazda OEM Pads (Street)
Stoptech stainless lines
Stoptech slotted rotors
Suspension:
Mazda R1 Suspension (upgraded shocks)
Gotham Racing power steering delete
Hinson Supercars outer tie rods
Wheels and tires:
Stock 16x8
Bridgestone RE750 225/60/16
Safety & Misc:
The Race Shop Street/Race roll bar
Weight with 2/3 tank (~70lbs) of gas: 2818lbs
Weight distribution: 49.9% Front 50.1% Rear
