F/S 1986 Mazda Rx7 with ls1/T56 swap. $8500 or best offer. See below for more details, car sits more than it gets driven so it has to go.
1998 LS1 engine with 108k, 99 wiring harness and PCM
2001 T56 with 140k
Ram Powergrip Clutch
MGW Short Throw Shifter
Custom 3.5" Cold Air Intake
C6 Corvette exhaust manifolds
2.5" x-pipe
C4 corvette drive shaft
Ronin LS1 Mount kit
C4 Corvette aluminum radiator
Ford Focus Cooling fans
Lokar Throttle cable
Fragola PTFE Stainless steel braided lines and fittings, PTFE hose won't break down like normal fuel line and its ethanol resistant.
Walbro 400 LPH Fuel Pump
Corvette Fuel Filter
Integra Speedo Mod
Aftermarket Hood and front bumper, don't know the brand
KYB AGX shocks
Ground Control Coilovers
Stainless steel brake lines
Mazda 929 Brake Master Cyl
7/8 Wilwood Clutch Master Cly
Stainless Steel clutch line.
Quick release steering wheel
Drag DR-33 wheels 17x8 fronts and 17x9 rears, tires are ok
Optima Gel Cell Battery
Aluminum Battery bracket
150 AMP battery Circuit Breaker
Complete Turbo II brakes and rear end
The car runs and drives great, paint is ok at best and the interior could use some work. call, text or email. 8O3-36I-897O jjmwhitehead@gmail.com, car is in Chapin, SC 29036
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
[attachimg=9]
[attachimg=10]
