Hey guys I am in the market for some new coilovers and I am setting my limit at 1.5k, that is my budget limit.
I currently have hipermax II's, I have to recheck. I can tell you the ones in the rear are done at least.
I have searched and read through a few threads, and instead of bringing up an old one I started this puppy.
I will be running a single turbo setup (wish was a twin, but again budget.) using the truck manifolds.
I am aiming only for 600whp right now, for the summer. I plan to take it to the drag strip often, and it will
be a daily driver(whenever the weather is great, why not.) and a weekend cruiser. I would like to get it on the track
out here in Portland (PIR)but that is at the back of the list.
My setup will be battle version rear lca's/toe links, super pro bushings, ronin 8.8, with at least 305mm tires in the rear, with the single turbo setup in the front. The car is using the grannies kit(the high mount one)
Not sure if I will be able to squeeze a cage in budget wise right now, but if I can I will.
Any suggestions would be appreciated.
