http://orlando.craigslist.org/cto/4332792334.htmlName: Chris
Contact: 386 (nine five six) 6472
Clean Title in hand
Thinking about selling my toy.
I bought this car about 8 months ago from a very good friend who is the original builder of the car and owned the car since 2004. I have daily driven this car since I bought it.
2001 Corvette Coupe
99k Miles
6 speed manual
Dark Bowling Green Metallic (1 of 919)
Light Oak Interior
619rwhp 541rwtq on dynojet dyno
Engine
346ci. 5.7L LS1 Short Block
MSD plug wires
Catch Can
LS6 Intake
2 BAR Map sensor
K&N Air Filter
Speed Density OS - HP Tuners- Tuned by Jeremy F of Fasterproms
317 Ported 6.0L heads
Speed Inc. SC-2 Cam 224 232 114lsa
LS9 7 Layer MLS head gaskets
918 Comp valve springs
New head bolt set
New Oil Pressure sensor
New Power steering pump and pulley
P1SC-1 Procharger (3 bottles new oil)
A&A 2 pulley bracket (2nd Gen.)
Quick change oil line
Tial BOV -- 50mm
3.4" Pulley on P1
3" Treadstone Intercooler
Pro Sport boost gauge with peak and hold
Fuel System
Racetronics (255 lph) C5 Fuel pump kit with harness (intank)
Bosch 044 pump with 8AN IN OUT (external)
Fuel pump harness for Bosch 044
Aeromotive 13101 regulator (boost referenced)
Camaro Fuel Filter Autozone FF4508 with -AN output adapter
Brothers Performance Fuel Rails with -8AN crossover
60# Injectors
Honeywell hobbs 77343 boost switch
Autometer Sport Comp electric Fuel Pressure gauge
Summit inline fuel filter
Summit Check Valve
Exhaust
LG Motorsports LG Pro-Longtube Headers
LG Motorsports Off-Road X-Pipe
MLS header gaskets
Magnaflow Catback 4 tip
Interior
Heads Up Display Installed
Dash integrated shift light set 5800RPM (Green LED)
Twin 2 1/16" gauge pillar pod
Secondary Fuel system ON indicator in pillar pod (Red LED)
Factory cut short shifter
Hurst Ball
Vette Essentials Leather Shift boot (Green/Lt. Oak)
Light Oak Lloyds mats (C5 logo)
Body matched door pulls
Sound deadening from under pedals to behind brake lights
Suspension and Brakes
Stock Brake Calipers
Hawk HPS front pads
AC Delco rear pads
Line Lock (activation switch under HVAC) \
VBP rear leaf spring
Z06 metal endlinks (x4)
Bilstein Sport Shocks (Lowered on Stock Bolts)
Drivetrain
Monster Stage 3 Clutch
Monster Flywheel
New slave cylinder
New Master Cylinder
Speed bleeder line on slave cylinder
2 x LG Motorsports Aluminum 12mm driveshaft couplers
9310 Mainshaft in T-56
Z06 3:42 differential built with Right and Left side 300M Steel shafts
DTE Transmission/Differential brace
Z06 solid bushing shifter box
Wheels and Tires
CCW Classics (17"x9.5"/18"x12") Polished Aluminum
Front Nitto 555 245/45/17
Rear Toyo RA-1 335/30/18
Electronics
Thunder Racing Colum Lock Bypass Simulator
Optima RedTop Sealed Battery
Trickle charger with quick connector to battery
6000K HID headlights (low beam) factory high beam
Pre-wired for Valentine One
Misc.
Z06 Front Foglight Screens
Wolfe C5/Corvette embroidered car cover
Tinted windows
Stainless C5 Logo Exhaust Plate
Car runs and drives great, No issues, No smoking, No knocking, No leaking, nothing. . .
Could use a headliner, and there is a small tear In the stitching on the driver seat bolster.
There are rock chips here and there, I mean it is a 2001 I figure this to be expected.
Price is 20000 but please no low balling. I will consider trades.....
Please don't think you will come here to test drive the car without cash in hand though.
I will be glad to take you for a ride.
I'm not here to bullshit anyone, or hide anything. If you have a question about the car please ask.
Sorry for the pictures, I'll get some better ones this weekend for everyone.
http://s270.photobucket.com/user/ChinkyChris/library/C5%20Corvette
