Well its time for me and my wife to test/sell our 1995 Mazda RX-7 base model non sunroof car initially had 115k miles on it at the time of purchase with the intention of swapping in LSx power. The odometer has 117k on it now. Clear title car. Only taken to the track once ran 10.8 @ 134 i really dont track the car. The car put down 541whp 520trq and weighed in at 2760 without me in the car. Car is in great condition for the year and i take care of it as much as i can. We have owned it about 2 yrs and built it in our garage. Started as a 95 blown motor shell and has come to this now. We hate to sell it but i think its time to move on. This is our 2nd lsx FD we have done. We have rebuilt this car from the ground up with almost every part replaced or upgraded down to the wheel bearings and pivot bushings.
Vin# JM1FD333XS0400348
Engine
HKE built 427 ls3
New core ls3 aluminum block
new ls1 oil pan setup
Arp head and main studs
PRC CNC ls3 heads double springs 650.
Stainless intake valves
Powerbond ls1 damper pulley
Manaul billet tensioner belt
Custom ls1 harnes with upgrades plugs for 42 lb injectors
Hke custom comp cam
Comp push rods 3/8
New gaskets with trays
New water pump
Melling high volume oil pumo
N motion double roller timing chain
All new sensors
Ls7 maf
Wiseco 4.070 pistons 3cc
Callies rods 6.125
Callies compstar crankshaft 24 reluctor
Custom oil catch can
Ported and matched ls3 intake manifold
Cable ported 90MM throttle body
New ls3 rockers
Exhaust:
Vibrant 5 inch straight thru muffler
Magnaflow y pipe
Stainless steel 3 inch piping catless
JTR ceramic heat caoted 1 7/8 long tube headers
V bands
New 02 sensors with rear deletes
Exterior:
99 spec bumper
99 spec turn signals
99 spec front spoiler
Feed shine skirts
Shine Carbon fiber low spoiler
99 spec tail lights
Car has been repainted and looks good. Little chips from ddriving but still great condition
Alimunum door handles
Shine street rear diffusser
20% tint
New windshiled
8k hid kit
Wheels/Suspension:
CCW classics 18x9.0 18x10 rears
Mickey thompson E/T streets 275/40/18
New 245/40/18 front tires less than 2k on them
Rebuilt powerdercaoted front and rear calipers
Hawk pads front and rear
Stainless braided lines Front and rear
Crossed drilled rotors front and rear
Super pro bushings kit installed 28 bushings
Powdercoated arms chrome
Megan trailing arms
Megan tie rod arms
Megan track coilovers with upgraded rear springs
New wheel bearings front and rear less than 2k on them
Rearend:
Cobra irs
3.73 gears
New clutch pack
New seals installed
Dss axles 700hp
Samburg rear cradle
Steeda solid bushings
Dss aluminum driveshaft less than 2k on it
Powdercaoted custom rear diff cover
Interior:
Mint suede r1 seats
Carbon fiber dash kit
New vent plastics
Led lighting replaces dim factory ones
Dual pillar dash
Oil pressure gauge
Water temp gauge
Speedometer and other guages work on cluster as they should
Suede shift boot
Cobra knob
Sony mp3 cd player
Kenwood speakers all around
Jdm efini steering wheel with carbon fiber center cover
Interior is complete
Battery relocated to rear bin
New carpet and matts
Transmission:
2001 T56 stage 2 from texas drivetrain only have 2k on it
Stage 5 spec clutch with aluminum flywheel
Hurst shifter
New slave cylinder
Wilwood master cylinder
Steel braided clutch line
Steering and mounting:
Samburg kit
Bump steer tie rod ends
New depowered rack feels real solid
Super pro rack bushings
Cooling/Fuel systems
Car has heater no AC
Samburg radiator v2
170% stat
New ls1 water pump
Corvette Fpr with braid fuel lines
Walbro 255 in tank pump
Ls3 42lbs injectors
Fuel gauge on rail
Cons :
For the cons on the car thet i can see or tell from owning it.
Driveability little bucking at low rpms my tuner keeps telling me cam size is the issue. Not a issue to me.
Little whine when at higher speeds 60-70 mph nothing major just stating it.
No AC other than this its a great car . Please serious offers. Please keep the bad comments to yourself.
Asking: 38k OBO serious offers please no trades please
Contact:832-755-4661 Andy text or call
Email: angautoworks@yahoo.com
