Ronnin 8.8 Review:
Design: You can read through this thread to see all the design changes they made, although it took longer than originally discussed, the extra time was well spent cause I think the design is great. Although a bolt in option would have been nice, the weld in option had everything I wanted. Compact design while offering the most durable setup on the market. This kit also give you an amazing amount of room for exhaust routing.
Quality of kit and components:
The overall quality of this kit is great. The welds, laser cut plate and bent tubes is top notch. The hardware, axels and boots look to be excellent quality as well.
Two Problems that I encountered:
1) The weld on the bushing rings protruded above the ID of the bore which would have made it very hard to install the bushing. This was a super easy fix, about 2 minutes with a sanding drum and it was clearanced.
2) The second problem was the actual fitment of the front cross member. One of the upper mount was about 3/16” away. After talking with Joel, he gave me a few tips: First, try to determine if it was binding somewhere. I found that it was hitting some factory welds on the lower front. I also took a very small amount off the ends of each bar to get it to sit a little lower and tighter. I got all the gaps down to less than a 1/16”, actually the top one was nice a tight.
Both of these issues are really not a big deal and fully expected with a kit like this. I just want to give the most accurate feedback I can so potential buyers know exactly what they are getting.
So far I am very impressed with the kit. Everything you will need is included, the quality is excellent and I think it is going to outperform any other kits/rear ends on the market.
Here are a few more pics:
Initial fitment, notice upper left arm:
After clearancing and welding in ( I forgot to take pics of it tacked in.. DOH):
