I plugged the lower port on the MC, put the LL after the stock proportioning valve, and put a T after the LL. Used adapters and some AN3 hose, & didn't have to cut any stock lines, I just re-bent the LF line. I also scrounged up a 10mm brake line T from a Toyota corolla to make it work.
I can list part numbers if needed.
