August 18, 2018, 02:43:11 PM
Author Topic: FD AC system made with or without cores.  (Read 22174 times)
Offline Random
  • Pre-Staging
Re: FD AC system made with or without cores.
« Reply #30 on: March 16, 2011, 11:03:16 PM »
I just did Dixon's car today I put 6oz of oil in it with 1.2lbs of 134.
Was that 6oz into a new (dry) compressor? I'm at that point now...
New system with new everything (except the evap core) and the question at hand is... how much oil goes in?
Thx in advance.
-Joshua
SOLD - '94 FD Money Pit: LS1, RSGear F-Body T56 w/ Magnum guts, RPF1s (18X9.5) on all four corners, Pettit TrakPro-StgIII, Improved Racing goodies, MGW, Powerflex bushings, and my own blood and sweat (and maybe a tear when she started for the first time).
DD: '14 Honda Ridgeline
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #31 on: March 17, 2011, 07:14:57 PM »
No that was a used one from his car.
a new one should come with the amount of oil you should use.
Josh
Stig's sunglass wearing American cousin
74 MGB GT V8 12.83 (75 shot)
93 402 LS2/T56 Rule 3 No V8 RX7's
TinMan09
  • Guest
« Reply #32 on: May 01, 2011, 03:01:04 PM »
You got an A/C set up for a LS2?
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #33 on: May 02, 2011, 02:29:58 PM »
Not much different for hard parts.  Just the fittings on the compressor I believe.
Josh
Offline atli126
« Reply #34 on: May 09, 2011, 01:01:14 PM »
did you come up with lines for the fc setup yet?
-Bret
Offline dream36realms
  • 死*神*
    • My favorite link
« Reply #35 on: May 09, 2011, 03:17:43 PM »
Is it possible to use the AC compressor from my LS1 on my first gen? If so, next winter I will be buying lines off of you ;)
日までに仕事および夜までに虐殺。
を下って、人類と
05_Raven
  • Guest
« Reply #36 on: June 06, 2011, 09:29:04 PM »
you have a PM. thanks
05_Raven
  • Guest
« Reply #37 on: June 14, 2011, 06:48:21 PM »
Are the custom lines w/o a core still available? I'd like to buy a set.
Offline Icemastr
  • Pre-Staging
« Reply #38 on: July 05, 2011, 09:39:20 PM »
09 GT-R - Daily Driver
93 LS1 RX7 - Trackable Street Car
Offline ltsr
« Reply #39 on: July 20, 2011, 01:23:59 PM »
Pez - does your kit include the line from the F-body compressor? or do I need to save the lines from the camaro? I'm about to sell my chassy and just want to know before I send it off. Sent you a PM. Would like to order  :)  thanks
///M
Offline thetastelingers
  • Rotors are for brakes
« Reply #40 on: July 20, 2011, 04:38:48 PM »
You need to save the lines off of the LS1 compressor. He will use those to build the new ones.
wazzaaaaaaaaaaaapppppp!
Offline shakenbake
« Reply #41 on: August 11, 2011, 07:01:27 AM »
The only lines I have ever sent him were the FD lines going into the firewall. Greg uses a custom adapter for the back of the GM compressor.
ls13rdgen
  • Guest
« Reply #42 on: February 07, 2012, 09:21:31 PM »
You can use the stock a/c lines off a f body requires a little bending ,cant be in a rush and  take your time . and just change the ends and have them crimped on.Why are you all changing the condenser just use the stock one that came with the car.
Offline Pez
« Reply #43 on: February 07, 2012, 09:41:09 PM »
Different condesnser because the inlet and outlet are on the same side, unlike stock.  Makes for a cleaner install.  And you have to make custom mounts for the stock one anyway.  New condensers are only like $80.
Offline JDMRrevolution
« Reply #44 on: February 29, 2012, 03:13:20 PM »
Sent you a PM. Interested in getting a kit. :drive:
Pm me when you can. Thanks
