August 18, 2018, 02:41:47 PM
Author Topic: FD AC system made with or without cores.  (Read 22173 times)
Offline hayabusa
Re: FD AC system made with or without cores.
« Reply #15 on: July 23, 2010, 10:58:35 AM »
yes a 04 gto pcm
Offline GEAUX FAST
« Reply #16 on: July 24, 2010, 05:37:15 PM »
ok, got the car... finally... made a few blocks today and WOOOOOOOOOOOOOOWWW these cars are the most attention getting beast i have ever seen, with  the slp loud mouths talkin every body says "dam"! Drives like it is on rails...
now if I am going to continue to enjoy this baby im going to need some serious cooling horse power!
Pez, Do you need pictures of under the hood? Its the Hinson radiator and mounting hardware. The threaded connections are on the firewall but I'm not sure if they are metric or otherwise. ac blows, lights up at the switch etc. so I am assuming all the Mazda parts are there .. Do you know if anyone has a picture right op on the wiring? Is your book still available to purchase? currently I have no compressor, bracket or anything in that area of the motor so I assume I will need to purchase EVERYTHING for the GM side of things ..
Offline GEAUX FAST
« Reply #17 on: July 24, 2010, 05:39:00 PM »
and it is running the JTR long tubes
Offline GEAUX FAST
« Reply #18 on: July 26, 2010, 12:08:07 PM »
Im losing my mind.... mod please delete all my eroneous duplicate post....
Offline Pez
« Reply #19 on: July 26, 2010, 12:40:22 PM »
Check the first post on this thread.  PM me your # and I'll call this evening.
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #20 on: August 31, 2010, 10:50:38 PM »
I just did Dixon's car today I put 6oz of oil in it with 1.2lbs of 134.  sitting at idle in the shop it was making 60 deg air from the vents and driving it makes 42.  Low side pressure was 45-53 and high side was 295-335.  I never got the sight glass to clear up but if I added more the high side would get to high for what I wanted.
Josh
Stig's sunglass wearing American cousin
74 MGB GT V8 12.83 (75 shot)
93 402 LS2/T56 Rule 3 No V8 RX7's
Offline mdpalmer
« Reply #21 on: November 01, 2010, 03:50:45 PM »
Anyone have recommendations for a condensor compatible /w Samberg's radiator kit, version 2.0 (or whatever the currrent one is)?
EDIT: I'm a dummy, he posted it in his available parts for the FD
http://cgi.ebay.com/ebaymotors/Universal-A-C-Condenser_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQitemZ140277905793QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
« Last Edit: November 01, 2010, 06:30:35 PM by mdpalmer »
Mike
My Build Thread
YouTube Vids
Offline Pez
« Reply #22 on: November 01, 2010, 05:46:51 PM »
Samberg used to provide a part number for the condenser that is compatible with his radiator.
Offline Jordan Innovations
    • Jordan Innovations
« Reply #23 on: November 01, 2010, 06:53:27 PM »
One of the things I've never tackled on a swapped FD is the AC... I've got the LS1 AC compressor and bracket, and the heater core/ac box behind the dash, what condenser is everyone using on the Hinson radiator and upper bracket/panel?  I assume it's the stock FD one, but since I don't have that, is there another option I should go with that's better?
I'll definitely be buying one of your kits Pez, just need to find a condenser!
Offline Pez
Offline rex7fd
« Reply #25 on: January 15, 2011, 11:16:47 PM »
Pez you are doing my harness in a couple of days when it gets there,  I think I will be getting this to maybe in 4 months.  It has been 28 outside so no rush for me right now.
94 FD/2002 LS6, 228/230 Comp Cam,  With Comp Cam everything,  Atomic Rex 360mm 6 pot frontsx 330mm 4 pots rears, Samberg everything, ARP everything,ported Lingenfelter TB, Ram twin plate. Nor Cal AG T-56. RUNNING!!!!!!!!!!!!!!!!!!!!!! 390whp/390tq
Offline Sabre002
  • My Shit is Custom
    • Panic Motorsports
« Reply #26 on: January 18, 2011, 12:11:07 PM »
I just got one off Ebay for Dixon
I think it was 14"X22"
Josh
Offline atli126
« Reply #27 on: March 06, 2011, 11:28:56 AM »
Any word on fc systems or lines
-Bret
12leavu
  • Guest
« Reply #28 on: March 10, 2011, 10:37:47 AM »
in the op i dont see a pressure switch mounted in line, but it scottmans pic of a kit he got from you it has one. why is that?
Offline Pez
« Reply #29 on: March 10, 2011, 11:48:41 AM »
OP there is a pressure -sensor- port right beside the low service port, on the strut tower.  On Scottman's pic, he's using the pressure -switch- because he's using a GTO PCM, which doesn't control AC.
