May 03, 2024, 10:31:56 AM
Author Topic: 94 RX7 LS1 W/T56 GREAT DD  (Read 10316 times)
Offline KEVIN8086
« on: March 27, 2012, 09:28:11 PM »
RX7 BUILD
346 CI Built by Leos Speed & Machine, Tuned in Cedar Park by Reckart Performance Turning      415WHP  370 WTQ
 MILAGE 86,689 and counting, this car is not my daily driver but easily can be and I like to drive it so the miles are going up weekly.
     - Stock Crank
     - Scat Forged Rods
     - Probe Forged Flat Top Pistons
     - Coated Bearings
     - Ported & Polished 241 Heads by SLP
     - PRC Gold Spring Kit  W/ Titanium Retainers, Seats & Seals
     - TSP Chromemoly 7.40” Pushrods
      -TSP  Custom Grind Camshaft  232/234, 595” / 598” ,  114 LSA
     - LS6 Intake
     - Stock Throttle body and MAF
     - MSD Plug Wires
     - Oil Catch Can
New Paint Montego Blue in February 2012 (engine bay was not painted)
Ceramic Coated LT Headers
Aftermarket Aluminum Radiator from RX7
Freshly Built T-56 Tansmission
Custom Front Sub Frame
Custom Transmission Mount
Custom Rear Subframe
SuperPro Polyurethane bushing kit installed on the rear, I have the Front set but not installed
Brand New Front Wheel Hubs (NOT INSTALLED)
Stance Coilovers
Gram Light  57 PRO Wheels  18x9.5 F  18x10.5 R
Kaaz Rear Diff 4.10 gears
Walbro 255 Fuel pump
Stainless Fuel lines from engine to connectors under car
Z06 Return Fuel Rail W/Vac FPR
99 Tail Lights
99 Spec front chin spolier
Viper Alarm
Low Oil Pressure Light, Mounted on steering wheel. It will light up like a shift light if the oil pressure  falls
Battery Relocated Behind Driver Seat
Gold Shielding on Firewall
Transmission Tunnel Heat Cover From Gold Foil Back to include whole Tunnel. Interior does NOT get HOT on your feet or the center console.
Whole new AC system, lines, Expansion Valve, Accumulator, Compressor
The motor runs perfectly.  At idle it holds a smooth 900rpm but when you step on it she is very responsive and with 500hp you can imagine the fun.  The car has ICE COLD!!! AC
The interior is very nice, 8 of 10 I would say, Exterior is very nice as well. Some of the coating on the wheels is peeling and does need to be taken care of in the future, all 4 wheels can be repaired for whatever you would like for $500 and can be custom colored if you don’t want it all chrome. Power steering works perfectly. All power windows, locks and mirrors work just fine. I don’t know what else I may be missing other the this car will be missed, it runs great, sounds amazing and turns heads like crazy.
ASKING 24,500 but open to offers  I DO NOT NEED TO SELL SO PLEASE DO NOT SEND CRAZY LOW BALL OFFERS, THANKS FOR LOOKING
THE NEEDS TO BE FIXED (or not)
Driver Door pocket lid, I have the lid but the little tab that holds it is broken, I may fix this with a tiny screw.
Missing Speaker Grills for the speakers behind the seats. There was a roll bar in the car and that was part of the mounting points.
No Front Door Speakers, The MDF spacers were bad and I have not gotten new spacers for speakers, there are tweeters in the door panels and 6x9’s on the rear package tray cover.
The windshield and hatch glass molding need to be replaced
Stock Antenna removed and there is still painted tape there from when the car was painted because I don’t know what I want to do with it, I didn’t want to weld and seal it up in case someone else wants the antenna there
Rear Wiper also removed and the hole is covered from the inside with dynomat backing for the same reason as the antenna
99 Spec front lip fell off on one side and scraped on the hwy beyond repair so I cut both sides at an angle to match so it wouldn’t look so bad
Driver side door sill panel missing, im looking for a used one currently
« Last Edit: March 27, 2012, 09:57:09 PM by KEVIN8086 »
Offline KEVIN8086
Re: 94 RX7 LS1 W/T56 GREAT DD
« Reply #1 on: March 27, 2012, 09:33:50 PM »
Offline KEVIN8086
« Reply #2 on: March 27, 2012, 09:35:24 PM »
Offline KEVIN8086
« Reply #3 on: March 27, 2012, 09:36:57 PM »
Offline KEVIN8086
« Reply #4 on: March 27, 2012, 09:39:31 PM »
Offline KEVIN8086
« Reply #5 on: March 27, 2012, 09:43:11 PM »
Offline KEVIN8086
« Reply #6 on: March 27, 2012, 09:44:41 PM »
Offline KEVIN8086
« Reply #7 on: March 27, 2012, 09:47:03 PM »
Offline KEVIN8086
« Reply #8 on: March 27, 2012, 09:49:51 PM »
Offline KEVIN8086
« Reply #9 on: March 27, 2012, 09:54:44 PM »
Offline jparker7
« Reply #10 on: March 27, 2012, 10:01:02 PM »
whats the offsets of your wheels
Offline KEVIN8086
« Reply #11 on: March 27, 2012, 10:15:06 PM »
i actually do not know the off set by memory, i would have to look at the wheels
Offline KEVIN8086
« Reply #12 on: March 28, 2012, 06:56:54 PM »
here is a quick video i took today while driving and holding my phone, a little difficult but you get the idea of acceleration, sound kind of sucks but not horrible.
Offline fastrx7man
« Reply #13 on: March 29, 2012, 01:17:19 AM »
Kevin...i sent you an email...I know it's a crazy idea.  Let me know what you think.  I figure i would through a picture up or two...so people can see the history.  I owned this car for almost 3 years.  Kevin has done a fantastic job keeping this car looking awesome...
9 years ago this was one of the fastest stock motor, stock twin RX7's in the country.
604RWHP at 17PSI (Little 2 liter rotor motor)
3 Rotors are almost as fun as 8 cylinders
Offline mooseknuckle3835
« Reply #14 on: March 31, 2012, 06:09:33 PM »
Id be interested in the wheels if the buyer doesn't want them.
