I have gone through so many oil pumps and heard to much wrong information in the past it’s not even funny.
This is the LS1 oil pump I ported and put in Roman’s FD.
This is a very good porting how too.
http://www.andersonperformance.net/LSx_Oil_Pump_Porting_v1.2.pdf Stock trim
After I got done with the outlet
This is the pickup after
Now that pump above made 35PSI hot idle with 5W-30 in it for street use. As far as I know that engine is with its new owner and running fine.
Here is the pumps we had show cased today.
From left to right. LS6, LSA, LS3
Here are the springs we had on hand between a friend and I. For a side note for later the last spring on the right is what was pulled out of the CNC ported pump from Katech.
LS6
LS3/5.3 PT# 12586665 this is the standard LSX pump from GM for now. I find it in most trucks I take apart that have AFM or not.
LSA/ L99 (VVT is the key) PT# 12612289
Now if you notice the LS6 and the LS3 pump are for the most part the same. The casting is a little new for the LS3 but it’s the same size pump in every way. I measured the thickness of the gears on all, the depth of the oil spring plug, Also that the spring in the LS6 and the LS3 they are different colors but are the same spring.
Here is where it gets interesting.
Here is a ported LS6/LS3 note above oil pump.
http://store.katechengines.com/gen-34-oil-pump-p5.aspxHere is a ported 23% high volume oil pump. (LSA/L99)
http://store.katechengines.com/high-capacity-gen-34-oil-pump-p272.aspxHere is what you will get, the ported inlet and that last spring in the pic of springs above.
Here are the stock inlets from the two pumps I got
LS3
LSA/L99
From day one I have seen ported pumps be in the high 100’s and I have took apart to many to count. The one thing I notice is most doesn’t touch the outlet. When the outlet porting use to be the norm. Hell pick up the HP LS1 book wrote buy the guys from MTI and GMHTP look for yourself.
Here is the millings pump that failed
